OT? Wiring a Kill Switch on my Kid's GoKart?
Discussion in 'The Hokey Ass Message Board' started by NealinCA, Sep 18, 2006.
  1. NealinCA
    NealinCA
    I understand gears and levers, but this electrical stuff always baffles me.
    I need to put a kill switch on my son's Gokart. It has a 7hp? Briggs...an old one from the early 60's. Here is the only pic of the engine that I have...
    Where do I break the circuit?
    Any help would be appreciated.
    Thanks,
    Neal
  2. Soviet
    Soviet
    You ground the ignition. Being that old, I'm guessing it still has the points setup. If you want to wire up a switch, you might need to pull the flywheel to get to the points cover if there is no lose wire sticking out. It's usually a pretty small wire that you ground to the block, and it kills the motor. Post of the pic of the ignition system- I'm not used to working with stuff that old, points ****. Also, if you want somethin simple, a piece of sheetmal bolted to the block that you press down onto the top of the sparkplug also works.
  3. 53sled
    53sled
    from KCMO
    wire it with a momentery switch to ground the plug. or use a piece of sheet metal.
  4. NealinCA
    NealinCA
    It does have the sheetmetal spark plug kill "switch", but that is kinda hard for a kid to reach around and hit in a panic situation.
    There is a small loose wire coming out of the flywheel cover? I will pull the cover off and see where it comes from and take a pic. Hopefully someone can figure it out from there.
    Thanks,
    Neal
  5. Bruce Lancaster
    Bruce Lancaster
    Before you pull the cover, just fireitup and ground that wire! If it stops running, that's it, and I can't think what else it could be. Just extend it to a switch that grounds it.
  6. hotrodbrad
    hotrodbrad
    from Tempe, AZ
    loop a shoe string round the plug wire so you can just pull the plug on that ****er
