OTish: JD2 bender issue
Discussion in 'The Hokey Ass Message Board' started by Concrete B, Oct 29, 2008.
  1. Concrete B
    Concrete B
    I've got a jd2 bender. As my tool collection gets bigger, and my garage got smaller, It's hard to keep it bolted to the floor away from the wall. Anyone ever made a mobile stand for one that you can fasten when in use? With that much torque, a mobile stand will surely move. Any ideas?
  2. stinkity stoink
    stinkity stoink
    from new jersey
    I rigged up a set up on a steel folding horse. I hook my porta power to it and go hydraulic. When I am not using it I fold the saw horse up and put everything away.
    It would never work if you are doing it manual though. I bought one of those cheap swap meet porta powers and it works well for me
  3. GreggAz
    GreggAz
    I made a trailer hitch based mount on the side of our frame table, which is on wheels. 2" chromemolly the table rolls a bit with the long cheater bar.
    you could mount it this way to just about any bench, just make sure that the bench is bolted down.
  4. beernut
    beernut
    from solvang
    my son (azwillis) made a mount that slid into his trailer hitch on his truck,worked fine
    now he converted it to elec/hydrolic and its on a roll-around stand that is a very nice setup
  5. seret
    seret
    I took a 2" pipe about 4 ' long welded a flange on top to bolt the bender to. then I stood it next to my vise and welded a 4"x8" plate to the pipe. basicly my JD2 clamps in my vise, via the plate and has a leg that suports the weight. Its worked for me for 2 years now. takes up no room, just lean it up in the corner, and when I want to use it I dont have to pick that bear trap up off the ground. if you like I can post a pic. Matt
  6. HemiRambler
    HemiRambler
    I punched the floor for some BIG Hilti HDI masonary anchors. With which I then screw in 2 LONG (and Large) anchor bolts sticking several inches above the ground (only when needed) I then roll the bender into place and viola - it's stationary. I've bent 1-1/2" OD .09 wall chromoly - no problems at all. When done I roll it out of position - remove the bolts - store them in the legs of the roll around frame so I don't loose them and roll the bender back into the corner. Worked for me.
  7. iagsxr
    iagsxr
    My first JD2 bender was manual. It was a PITA, there was always something parked(dead)over my anchor points. Got a chance to sell it and bought a new one with the air over hydraulic set up. It's sweet because it doesn't need to be tied down. I just pull it out to a level spot on my floor and have at. Another benefit is that if I'm bending something really long that I don't have room to swing I hang on to the material and the bender pivots. Beats using the tie down points I had in the driveway for such things.
    Put a quick coupler on the air over hydraulic unit and use it to run your porta power, press, and cherry picker too.
  8. bct
    bct
    my buddy has a big hossfeld and he anchors/moves it with his forklift...it has a channel on the bottom that the fork slides into....pretty tough to move a forklift...
  9. slddnmatt
    slddnmatt
    i have a trailer hitch receiver in flush mounted in my concrete, so i just drop it in when i need to use my bender.
  10. Concrete B
    Concrete B
    I like this. This would work well for me. The damn things just too heavy to be portable. I could add 2 castors and a handle, wheel it to my big vise, and clamp it down. Not sure what I'll end up doing. It'll be a while til I use it again. Just trying to organize the shop.
