Technical Outer bearing 49-54 chevy
Discussion in 'Traditional Customs' started by 68caddydaddy, Aug 31, 2023.
Tags:
  1. 68caddydaddy
    68caddydaddy
    Guys ,
    Does anybody know what type of outer bearing to use when converting to disc brakes. I read a lot on the sites that sell the conversion kits. Lots of info about the inner bearing type A13 (70s Ford). I own a 54 chevy 210 Handyman with stock spindles. I already purchased GM rotors 5519 type. Thanks !
  2. squirrel
    Maybe it's the same bearing that is used in the original application for that rotor, so no one bothers talking about it?
  3. 68caddydaddy
    68caddydaddy
    In an instruction sheet of MP brakes I found a description of an A2 bearing type
  4. Inner diameter of A2 is .750, check your spindle diameter to see if it's the same.
    68caddydaddy likes this.
  5. squirrel
    A2 is the outer bearing used in GM cars with disc brakes in the 70s, so yeah, I'd expect that's the right bearing. The outer end of the spindle is 3/4" diameter on most Chevys for decades.
    it's also the cheapest wheel bearing there is, so don't cost much to see if it fits. $2.22 each on rock auto
