Technical Over Charging?
Discussion in 'The Hokey Ass Message Board' started by ThompsonSpeed, Jun 18, 2014.
  1. ThompsonSpeed
    ThompsonSpeed
    Im working on a late 60s 383 in an old 50s dodge pickup. 12v system.
    Having some trouble with the charging system. It has an external regulator. Alternator has main wire for battery and two field wires that go to the regulator. Problem was that it wasnt putting out enough juice to keep the battery charged. Now that i had the alternator tested, all good, and put a new voltage regulator on, its over charging. Over 15....
    Am i possibly missing a ground somewhere? Did i get a bad regulator right out of the box?
  2. pat59
    pat59
    sounds like the regulator ain't regulatin'
    -Pat
  3. e1956v
    e1956v
    Alliance Vendor
    Check grounds and make sure you have a good ground to the base of the regulator.
  4. ThompsonSpeed
    ThompsonSpeed
    Thanks for the replies guys. I sanded both the firewall where the regulator bolts on, and the backside of the regulator itself. Didnt seem to help. I guess it might be bad right out of the box. Ill try to exchange it, and see if the new one does the same.
  5. Grahamsc
    Grahamsc
    from Colorado
    Is it an adjustable regulator?
  6. ThompsonSpeed
    ThompsonSpeed
    No its not adjustable.
  7. Helge71
    Helge71
    If it is one of these quite cheap new electronic regulators in the stamped "old style" steel box (shaped like the original) casing I would not discard the idea that it is bad right out of the box. I had the same in my '65 Pontiac, where I exchanged the original, old, slightly faulty mechanical regulator for a re-pop electronic version. It did massively overcharge and almost killed the alternator (alreday started to discolor due to overheating), the ampere metre and cooked the battery before I noted that something was wrong. It was just bad right out of the box and the replacement I got worked fine and still does since then...
  8. ThompsonSpeed
    ThompsonSpeed
    Helge71, thats exactly what it is. A cheap one made to look like the original. I got it at advance, i think ill take it back and try one from NAPA. Maybe have better luck.
  9. lothiandon1940
    lothiandon1940
    I know it's not the same scenario but, I replaced the alternator on my OT Corvette once yrs. ago (it's internally regulated). When I started the car all of the dash lights lit up so bright it almost blinded me. I turned it off immediately not wanting to tear apart the dash to replace about a dozen bulbs. Turns out the internal regulator was bad so it does happen even with new parts.
  10. squirrel
    Do you have the old style regulator, and the old style alternator? They changed around 1970. The old alternators have one of the field wires grounded, the later ones have it go to the regulator. Just wondering if your alternator and regulator match?
  11. Rusty O'Toole
    Rusty O'Toole
    I agree, you got a bad regulator. There is nothing to adjust, they are solid state. It is impossible to install them wrong, there is a plug that only goes in one way.
    There is supposed to be a ground wire from the engine to the body, on stock Dodges it is a small braided wire from engine to firewall. Also a ground wire from the alternator that disappears into the wiring harness. I think it goes to the battery.
  12. ThompsonSpeed
    ThompsonSpeed
    Squirrel, i believe its the newer style. Both field wires go to regulator, one splits off to go to ignition i believe.
  13. squirrel
    It's this style of regulator?
  14. ThompsonSpeed
    ThompsonSpeed
    Yep, thats it. Went to Napa, got the NAPA version, which looks cheaper than the advance auto version. Hopefully it works better.
  15. squirrel
    Does the alternator look like this? or does it have a more square looking area in the middle?
  16. ThompsonSpeed
    ThompsonSpeed
    Hmmm , it looks pretty similar to that, but I'll double check the looks of it.
    Also, same issue with the napa regulator. Over charging.
  17. Rusty O'Toole
    Rusty O'Toole
    Either you got 2 bad ones in a row or your wiring is messed up.
  18. ThompsonSpeed
    ThompsonSpeed
    I can't imagine I got two bad ones in a row, but stranger things have happened. I'm going to go through my wiring this weekend and try to see any issues. Thanks for all the input guys! Appreciate it!
