Over drive questions
Discussion in 'The Hokey Ass Message Board' started by The Worm, Feb 14, 2010.
  1. The Worm
    The Worm
    I have a 55 Ford truck Overdrive trans. Not sure what motor it was hooked up to. I have a 56 Ford truck with a 223 straight six. And i want to hook the trans up to the 223. I was wondering if the splins would be the same V8 and L6? Thanks for the help!
  2. PackardV8
    PackardV8
    If he's got the ******, he can measure the diameter and count the splines of the input shaft.
    Does the ****** have a top cover? Usually there is casting ID on the box. Could be a Borg-Warner T86.
    thnx, jack vines
  3. The Worm
    The Worm
    I don't know, but I'll look. Thanks for the help
  4. tommy
    tommy
    They should be the same.
  5. if they are different he just needs a disc that matches the trans.
