Hot Rods Over filled transmission
Discussion in 'The Hokey Ass Message Board' started by Cleetus, Mar 8, 2015.
  1. Cleetus
    Cleetus
    from Austin
    I am having some issues with my transmission. My truck is hesitating from the transmission.. I checked the trans fluid yesterday and it was way above the full line. Will it cause permanent damage to over fill a transmission?
  2. I'll ask the obvious. I ***ume it was running on level ground when you checked? Warmed up?
  3. Inked Monkey
    Inked Monkey
    Air bubbles from sloshing fluid are not good.
  4. squirrel
    Might depend what kind of transmission it is? I'm guessing it's an automatic. But that's just a guess.
    If you checked it with the engine running, and after moving the shifter thru the gears, and it's above the full line, then it will likely get air bubbles in the fluid, and may even push fluid out the vent tube when it gets hot. Not good.
    And most auto transmissions need to have the pan dropped a little bit to remove fluid. Not fun, but not difficult, either.
    HOTRODPRIMER likes this.
  5. Damage occurs when driving with aerated fluid. Usually can **** some out thru the fill tube.
  6. harpo1313
    harpo1313
    from wareham,ma
    Or you could get one of those oil change pumps for a boat and **** it out of the fill tube.
  7. HOTRODPRIMER
    HOTRODPRIMER
    [QUOTE="squirrel, post: 10882864, member: 3595"
    And most auto transmissions need to have the pan dropped a little bit to remove fluid. Not fun, but not difficult, either.[/QUOTE]
    Sage advice. HRP
  8. 54fierro
    54fierro
    from san diego
    Or you can try pulling a cooler line and start it up. Put some hoses to catch the fluid. You'll get a qt out after a few seconds. It's quick.
    I had to do this a few times when my ****** cooler went out and some coolant got in the fluid. After pulling the pan and changing the fluid I have been doing this periodically to try and get the all the coolant out.
    da34guy likes this.
  9. da34guy
    da34guy
    Now that's thinkin,
  10. rfraze
    rfraze
    Which of the cooler lines is output from trans?
  11. da34guy
    da34guy
    Makes no diff
  12. rfraze
    rfraze
    I can never remember. Always have to feel for heat, so am just asking which is output to cooler. It does make a difference.
  13. It doesn't matter which one because no matter how carefully you place the drain bucket, it will make a mess.
    tb33anda3rd and Andamo like this.
  14. SanDiegoHighwayman
    SanDiegoHighwayman
  15. 54fierro
    54fierro
    from san diego
    Haha. True.
    I can't explain it but until I put a fitting and hose on both sides I always made a mess. I had heard that the fluid always runs uphill in the radiator but didn't want to say that earlier because a lot of top tank radiators have the lines side by side.
    I got it down now. :)
  16. caton462
    caton462
    Could put a piece of brake line into the fill tube with a piece of vacuum line drooped to below the pan, blow compressed air over the end and it will siphon out.
  17. Lone Star Mopar
    Lone Star Mopar
    Pull the dipstick tube, if its to full it should pour outta there. Also a turkey baster in the hole will remove a qaurt pretty quick. Or just pull the pan and get one w a drain plug.
  18. ChucksCrib
    ChucksCrib
    from Uranus
    I've had to do this myself in the past.......as stated, disconnect the lines going to the radiator and turn the car over for a few seconds....check and repeat as needed.
  19. 55 dude
    55 dude
    good idea unless it a newer mopar because they have to be in gear or cooler circut isn't used!
