Overbored flathead experiences ?
Discussion in 'The Hokey Ass Message Board' started by mercjoe, Dec 29, 2007.
  1. mercjoe
    mercjoe
    Hey guys,
    Since I have not been able to drive my Merc yet..., it has been sitting on the body shop for the last 7 months since the engine was rebuild (hopefuly it'll be painted and ready on Feb.)
    I have some questions:
    The 255 was totally rebuild with new parts all over, Egge pistons, french rods, etc, etc.
    It was hot tanked for 2 days.., though rust just kept coming out endlessly. I think Im gonna have the radiator flushed and/or redone several times until rust dissapears.
    Anyway, cylinders were bored .040
    Im afraid Im gonna have to be really carefull about temperature.
    What were your experiences with your overbored flattys ?
    Thanks a nd happy new year for everyone
    Diego
    PS: I already have several bottles of distilled water, water wetter and Gunk water pump lube :D
  2. Fourdy
    Fourdy
    Mercjoe,
    I am .125 over. New radiator. I spent half a day rodding and cleaning out the block before I sent it out to be shake and baked. It is incredible how much junk you get out of these old blocks, sand, rust, dirt and even a piece of wire or two. I have run for two sumers now and no overheating problems. Electric fan doesn't come on unless I'm idling or in traffic. Never overheated. Oh, I also use stats.
    Just my experience.
    Fourdy
  3. mercjoe
    mercjoe
    Thanks Fourdy,
    And I thought .040 was the limit
    D.
  4. Ole don
    Ole don
    I run a 4 X 3 3/8 motor with Offy heads, it runs about 170 until it gets in heavy traffic on a 95 degree day, then it will climb to 205. I have Speedway water pumps, and stainless washers with a 5/8 hole in place of thermostats. If I used it often in cool weather I would put in 160 thermostats. I think half the heating problems in those motors was the ignition being off.
  5. mercjoe
    mercjoe
  6. Dale Fairfax
    Dale Fairfax
    .040 has only scratched the surface.
  7. Flatdog
    Flatdog
    3 3/8 is '187 over it ani't gonna run hot on you.Looks at some of the old posts on block cleaning.
  8. mercjoe
    mercjoe
  9. Bruce Lancaster
    Bruce Lancaster
    Flatheads are a COMPLETELY different game than modern thinwalls. 3 3/16 blocks will almost all go safely to 3 3/8, and many have raced at 3 7/16. 3 5/16 is considered a conservative hotrod bore. With engine at .040, you, your kids, and their kids cn rebuild the thing several times each,safely. Then, your great-grandchildren can press in some sleeves and start over.
  10. Bruce Lancaster
    Bruce Lancaster
    Sizes that are or have been commonly available and used for 3 3/16 motors: Oversizes of standard to 080, and an odd large oversize for factory sleeved engines with sleeves removed
    3 5/16, sometimes in oversizes...
    3 3/8
    3 7/16.
    Oversizes used to be available for the big sizes, too. I have some oversize rebore pistons for 3 7/16 in the ba*****t somewhere!
    New sizes are appearing now, because people are creating new sizes to use modern metricpiston ring technology.
  11. Shaggy
    Shaggy
    from Sultan, WA
    I pulled apart a 221 that had a lot of miles at .200 over... people say i should get it sonic tested
  12. mercjoe
    mercjoe
    Thanks for all the answers guys.
