1952-59 Ford OVERDRIVE PROBLEMS (AGAIN)
Discussion in 'Off Topic Hot Rods & Customs' started by Alan Freeman, Oct 11, 2024.
  1. Alan Freeman
    Alan Freeman
    I now have a working OD solenoid that I removed from another one of my cars. All of the OD electricals check out as good. After struggling with this problem for weeks and reading a long series of posts on "Ford Barn", I am convinced that my problem is mechanical and not electrical and caused by misalignment of the blocker ring with the pawl. The blocker ring must have rotated out of alignment with the pawl when I had the solenoid removed in the past. This problem is described on page 10 of the Borg Warner manual. I tried the remedy for this condition with the solenoid loosened but it didn't work. I made a tool to grab the pawl and push it inward with the solenoid removed while rotating the driveshaft by hand but I only feel about 1/8" movement of the pawl and I don't feel it dropping into the blocker ring no matter how many times I turn the driveshaft. Can someone give me a detailed description of how to realign the blocker ring without pulling the transmission and taking it apart? Should I have the OD dash handle in or out? Should I have the car in a forward gear or in neutral? I ***ume that the rear wheels should be off of the ground. Thanks
  2. JeffB2
    JeffB2
    from Phoenix,AZ
