1952-59 Ford overdrive relay
Discussion in 'Off Topic Hot Rods & Customs' started by vein, Sep 1, 2011.
  1. vein
    vein
    I was wondering where I could find one of these? Its the overdrive relay mine doesn't work and was looking to replace it. I have 3 catalogs and none of them have the overdrive relay. Or does anyone have one that is in good working condition? Thanks.
  2. Retro Jim
    Retro Jim
    Did you try MACS ?
    If you have a Hemmings , they have a couple guys that have hem and rebuild them in there . I have seem them before but you have to look in the front or the Ford section to find them BUT they are there .
    Jim
  3. vein
    vein
    Ill call MACS? How much to have one rebuilt though?
  4. vein
    vein
    No luck on macs.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. old lady's mad
    old lady's mad
    is your car 6 v. or 12v ? ive got some 12volt universal relays i can show you how to wire it up.
  7. vein
    vein
    Yeah it is like that one. Mine has a 30amp fuse on it. Mine has three prongs coming off it. The one in the picture looks different but same idea. The one in the picture looks like one of the tabs is broke off. Old ladys made I would like to know how to rewire it with a switch. I have done a search on the hamb but there is no real detailed info on it.
  8. old lady's mad
    old lady's mad
  9. vein
    vein
    yes, thank u for pointing me in the right direction, I would like to know how to wire it up. In the ford book it says 30amp can you use 40 amp?
  10. vein
    vein
    oh never mind the 30amp to 40amp question. I see that you get 2 30a and 3 40a in a packet I definetly still interested in how to wire it up. I have already looked at the wiring of whats in the car right now so hopefully its a easy hook up.
  11. old lady's mad
    old lady's mad
    ill go get one out of the detached and take a pic and make a diagram of sort. also they are made to be used in either normaly closed or normaly open. the smae relay can be used to make wigwag head lights along with a flasher.
  12. vein
    vein
    cool thanks! Im sure ill have some questions.
  13. old lady's mad
    old lady's mad
    heres the pic.
    the diagram is on top of the relay and the lugs are marked on the bottom. you can use the poss. or ground switched to turn it on.
    normaly closed means the contacts are closed the relay when activated opens the contacts.
    normaly open means the relay when activated closes the contacts.
    the load is on lugs 30,87,87a
    lug 30 is fused in. on this harness its the blue wire
    lug 87 is a load out normaly open, on this harness its yellow wire
    lug 87a is a load out normaly closed, on this harness its red wire
    the relay is turned activated by lugs 85,86
    lug 85 is relay ground black wire on this harness
    lug 86 is relay poss. white wire on this harness.
    want to make wigwags ? put a standard turn sig. flasher in the ground side one light on 87 the other on 87a . tie lugs 30 and 86 together on a 12v. switch and you got them.
  14. vein
    vein
    okay umm! I kinda understand. Whats a wigwag? Sorry. LOL. is that a toggle switch?
  15. old lady's mad
    old lady's mad
    wigwags are like cops do with headlights. one side on then the other side.
  16. vein
    vein
    HA! Funny me! shouldv'e known!
