Overflow bottle ideas
Discussion in 'The Hokey Ass Message Board' started by carcrazyjohn, Sep 14, 2010.
  1. powdercoater46
    powdercoater46
    I use an aluminum Miller Lite bottle.
  2. Teep
    Teep
    from Travis AFB
    the ground.
  3. Detonator, that looks like a 40mm Bofors casing, I guess I must digress I think it looks good.
    Superb! This is what we should strive to create for our cars.
    Doc.
  4. 60galaxieJJ
    60galaxieJJ
    I saw a empty bottle of tequila used for one once. Half the fun in that one is getting it empty. :D
  5. ct1932ford
    ct1932ford
    Well I planned on starting a thread and then found this one so here is my overflow tank that I just installed on my 32. I picked it up on ebay and it is from a vintage mercedes. Modified some stuff and made brackets to hang it off of radiator supports.
  6. hotroddon
    hotroddon
    Man, I think you guys are over thinking this. Trying to figure out how to make something ugly and non traditional look good, or at least not look like a sore ****.
    I can't show you mine (bottle, not the sore ****) because I made one that fits under the car attached to the frame so that no one has to look at it. Doesn't matter if it's ugly or not because no one can ever see it. It's completely hidden.
  7. plym49
    plym49
    from Earth
    Nice, but isn't it a little slim shady to mount your temp sender through the hose when you have that extension pipe right there? Just sayin'.
  8. ct1932ford
    ct1932ford
    That is the way they did it back in the day. They made a kit for it. I have just finished the complete redo of the car and now running two temp gauges (check out the senders) Also my new overflow bottle.
  9. Brad54
    Brad54
    from Atl Ga
    Seeing the green in the bottle makes me think an absinth bottle would be cool.
    -Brad
  10. fleetside66
    fleetside66
    Here's mine, made in 1946 of aluminum.
  11. mgtstumpy
    mgtstumpy
    Have an O/T S/S one and replacing with a period correct canister. I also have the proper generic GM decal rather than the Chevy one
  12. LN7 NUT
    LN7 NUT
    Didn't feel like going through 7 pages, sorry if it's been posted but i have seen a Mountain Dew bottle used, and the coolant is the same colour as Dew... so it's kinda cool.
  13. iwanaflattie
    iwanaflattie
  14. LN7 NUT
    LN7 NUT
    lol
  15. 32Rules
    32Rules
    Made this 64 Corvette surge tank into an overflow tank on my 32
  16. fatboys69
    fatboys69
    from Tennessee
    I just picked up this tank at a swap meet to use for mine.
    gonna mount it to the spreader bar. Its a fuel tank off of an old
    military generator
  17. Six-Shooter
    Six-Shooter
    from Ohio
    Colt 45 Malt Liquor can on Six-Shooter, my T-bucket.
  18. I use a Harley Davidson beer can from 1986.
  19. wsdad
    wsdad
    Hidden Puke Can Idea:
    If your frame isn't already boxed, you could box a small section of it and cap off the ends. Thus, making a resivoir inside your frame. It would be nearly invisible - especially if you ran the fill hose and vent hose from the side of the frame that faces the engine.
    (Or, you could simply mount some sort of container there and paint it black.)
  20. Martin_F
    Martin_F
    Don't forget to put a drain plug in it!
  21. Once again, surfing the HAMB has been educational! I just learned that I can put this thing anywhere I want. I've been resigned to using the O/T plastic tank that was on the roadster when it was an altered. I can still use that tank, but it doesn't have to be out where everyone can see it. Does it ever have to be mounted so the level in it corresponds to the level in the radiator? Thanks!
  22. HealeyRick
    HealeyRick
    from Mass.
    Later MG Midgets came with a br*** expansion tank that can be polished up. They're easy to find on evil bay:
  23. 6-bangertim
    6-bangertim
    No, it doesn't seem to matter. All I've seen are mounted below upper tank level.
    On my '57 Black Widow trib car, I yanked the chrome POS the PO installed for a 2-qt. Stanly thermos I repainted silver (remember GREEN was bad luck on a race car!). A little bigger than i would like, but only paid $7 for it at the local swap meet. Sits in front of the sail panel, secured by a bungee cord hooked to the horn bracket and a red shop towel folded to cushion the bottom. Looks a little funky, but is PERIOD CORRECT. I would post a pic, but haven't seen anything here on how to do it. Any help?
    - Tim
  24. Von Rigg Fink
    Von Rigg Fink
    from Garage
    6-banger Tim
    look at the bottom of the post box..you see two boxes to click on..one says post quick reply, other one says go advanced
    click the "go advanced" when you do this a menu of options come up above the typed field..look for the paper clip icon and click on it..another window will appear and you will be able to browse for the location of your picture file..
    hope this helps
    Randy
