Overhauling an Olds 303 Engine need HELP
Discussion in 'The Hokey Ass Message Board' started by Hotrod_rick, Jun 1, 2011.
  1. Hotrod_rick
    Hotrod_rick
    I have an Olds 303 engine that is installed in a vintage dragster I purchased. The engine is missing a lot of parts internally. I purchased a good core that needs overhauling. I have no experiance with an Olds engine. Are there any manuals for this engine available? Can an early Chevy engine manual be used? All help will be appreciated in getting this piece of history back on the track.
  2. inline 292
    inline 292
    Look for a Olds factory service manual. The one their dealers used.
  3. FormerFueler
    FormerFueler
    Rebuild the core using an Oldsmobile manual. The Chevrolet manual is for a Chevrolet! Would you use a refridgerator manual to rebuild a stove?
    Not trying to bust your chops,Ask a lot of questions and I am sure the power of the H.A.M.B. will guide you.
    Alex lobos likes this.
  4. Hotrod_rick
    Hotrod_rick
    I guess it was asking a lot to mix apples and oranges. I just thought maybe the early GM V8's shared alot of similarity.
  5. Hotrod_rick
    Hotrod_rick
    I have found online a factory service manual for the entire car. In looking at the index it was hard to determine how extensive the engine chapter got into. I may just have to bite the bullet and buy it.
  6. turbostude
    turbostude
    from minnesota
    The factory manual is very comprehensive. You will find that a lot of pages are devoted to the hydramatic, which was a relatively new animal then. Though the manual suggests that you use "tool # 4567739" to do some job, I have never had a problem using the universal tools available for other cars. My guess is that you can get a used manual for about $40-60. It can save you more than that.......
  7. Paul
    Paul
    Editor
    used or reprint manuals are readily available, afordable and invaluable
  8. mickeyc
    mickeyc
    Check out Ross Racing in Ohio Tony goes by Goat Roper here on the hamb. He knows Olds.
  9. roseville carl
    roseville carl
    Hey Rick I have an Old motors manual that should be of help give me a call.............Carl
  10. RichFox
    RichFox
    Or look on Ebay for a Motors manual from a few years later. No big secerets in a '49 Olds. Rocket
  11. mr50s
    mr50s
    Hey Hotrod Rick,
    About 11 years ago, I purchased a new reprint of the "1950-51 Oldsmobile Shop Manual" for $65.00 from Kanter Auto Products in Boonton, NJ. Their website is www.kanter.com. This manual is about 1-1/2" thick and 8-1/2" x 11" in size and spiral-bound for ease of use on the workbench. Info. is very complete and detailed and should answer many of your rebuild questions. Kanter also carries many of the parts used in a total stock rebuild. But if you're thinking of a Hot Rocket that smokes the tires, give Tony at Ross Racing Engines in Niles, OH. a call. Ross builds bullets like that all year long AND they are H.A.M.B. members!
    Before you order the manual or make your calls, be sure you have accurately pinned down the year which your block was first manufactured. The info. to do that is listed in an Olds tech. article on this very website. Or if you'd prefer, give us the block number and one of us Olds guys can look it up for you and post the results.
    Either way, you've got a great engine that makes lots of torque and horsepower and is COOL to hear and look at. Keep us posted and good luck!
    mr50s
  12. oneqwkfbody
    oneqwkfbody
    check this out. http://www.442.com/oldsfaq/ofe303.htm
    i have a 53 olds with the 303 4 barrel. its a fun engine....and seems like the hardest part for rebuilding would be finding parts...if its NOS you are looking for then kanter and/ or fusick www.fusick.com would be good places to start. these engines have lots of history to them,...and im amazed everytime i read about them here and on the interweb. good luck!!
  13. N43
    N43
    I know this thread is a little old. I will be rebuilding a 303 soon and agree with all of the above plus watch Ebay and Hemmings. Don't forget H.A.M.B. cl***ifieds. Even Google and local Craigslist searches turn up suprises.
    A word of caution, I am hearing is that there is an internal plug in the oil circuit on early Rocket V's that machine shops overlook reinstalling. If it is missing, there is no oil pressure to certain areas and the engine fails quickly.
  14. Mr48chev
    Yep, that is the best way to know exactly what steps you need to do on the engine. They usually cover every step in the operation and it reads as if they don't ***ume that the mechanic automatically knows what is going on. Figure out what year the engine is and usually you can find a manual on Ebay if you don't have a swapmeet coming up close by.
    it looks like you can get one for about 40 bucks on Ebay. Be careful as there are several that only are for the AC or transmission that are about 10 bucks that aren't any good to you.
  15. Dave50
    Dave50
    Talk to goatroper tony he is has everything u need
