Technical Oversize Mopar Lifters
Discussion in 'The Hokey Ass Message Board' started by fargo36, Jun 1, 2022.
  1. fargo36
    fargo36
    Hi all, I'm trying to cure a noisy lifter situation at start up, on my 341" Desoto powered Deuce. I suspect worn lifter bores - one or more. I realize the ultimate solution is a tear down and lifter bore bush, but would like to try a couple- or more- .001 oversize diameter lifters if I can find any. I am currently using 440 Mopar lifters and adjustable pushrods - due to a cam grind- with larger diameter lower ball ends to mate with these lifters. Mopar used to market .001 oversize at one time. Does anyone have any they would part with, know an accurate part number, or know a supplier? Any info would be appreciated. Thanks, Don Harrington, Ontario Canada. 905-957-3489 harringtond48@hotmail.com
  2. slayer
    slayer
    If I remember correctly, the oversized Molar lifters were .020 oversize to correct factory defective blocks. How much preload are you running on your lifters?
  3. PackardV8
    PackardV8
    My experience is worn lifter bores manifests as low oil pressure. Are we discussing hydraulic lifters here?
    jack vines
  4. oldiron 440
    oldiron 440
    It’s been a long time but I think it’s the Ford FE lifter bore size that is used to clean up the mopar. I’ve heard it both ways, mopar had a batch of blocks with lifter bores oversized and they first got a few thousand sets of lifter’s that were over size then there’s another story where Chrysler would fit individually lifters in lifter boars On each engine, yea right.
  5. PackardV8
    PackardV8
    You're like me, old iron. Going back into the memory banks is likely to get some seriously bad intel. The FE lifter is only .874" and the Mopars have always been .904".
    jack vines, who feels like s**** iron when he gets up in the morning
    lemondana and Charlie K like this.
  6. oldiron 440
    oldiron 440
    Maybe it’s 429? Sometimes I think I’ve forgot on more than I ever knew. Lol
  7. 73RR
    73RR
    There are several lifters with appropriate diameters but it appears that the 'wrong' lifter is currently being used.
    This tells me that the 440 lifter being used is 68-up and certainly will place the oil feed groove in a less-than-desirable position with regards to the window in the bore. This is the same issue as using the HT2011 LA lifter, yeah they work, kinda... If the lifter does not see the window long enough then oil supply will suffer.
    The proper lifters, VL-8, or HT812, are available so why not use them?
    CAUTION: Comp Cams 812 lifter is for a sbc...not useful.
  8. fargo36
    fargo36
    Thanks to all who responded. I now have a set of Mopar .001 oversize , will pull it down this winter.
  9. Ericnova72
    Ericnova72
    from Michigan
    Nope, 429-460's are .875" just like nearly all mid 1960's and later Ford V8's.
