Technical Overspray on Glass
Discussion in 'The Hokey Ass Message Board' started by blowby, May 2, 2022.
  1. blowby
    blowby
    from Nicasio Ca
    Got some 2k primmer overspray I need to remove. Acetone, Goo Gone ain't cutting it with a rag. I've used fine steel wool in the past but this is a perfect new windshield I don't want to hurt. Razorblade, Scotchbrite, some other chemical? Getting conflicting info on the www.
    dana barlow likes this.
  2. Get a clay bar, best invention ever. When I painted my T I got overspray (light blue) DOH!!! on my folks TWO new cars (red and white). With a little soapy water and a clay bar it wiped right off, even on the gl***.
    blowby, mad mikey, Tim and 2 others like this.
  3. 19Fordy
    19Fordy
    blowby likes this.
  4. FrozenMerc
    FrozenMerc
    Razor blades work well, just s****e it off.
  5. jimmy six
    jimmy six
    Razor blade then clay bar…
    blowby and olscrounger like this.
  6. 19Fordy
    19Fordy
    72yenkonova, blowby and 1oldtimer like this.
  7. guthriesmith
    guthriesmith
    I have always just used razor blades.
  8. dalesnyder
    dalesnyder
    I would never have thought of using a clay bar.. definitely gonna add one to the tool box..
  9. jnaki
    jnaki
    Hello,
    Overspray comes off just about any surface with lacquer thinner. It is stronger than acetone and is the last resort to remove something like dried on spray. But, if lacquer thinner drips on something, it may melt the stuff. Use a pair of gloves, pour the stuff on the rag and wipe.
    If the stuff does not come off in a wipe or two, then drip some lacquer thinner on the spray directly on the gl***. I have a clay bar and for me, does not work on something like overspray.
    Jnaki
    We got my wife's other older station wagon back from the body shop. They had to spray the rear door and got some on the gl***. No one saw it until I cleaned the rear gl*** to go somewhere. Then I noticed the over spray. I wanted to use the single edge razor blade, but did want to accidently scratch the gl***. So, several drips of lacquer thinner on a rag and the spray stuff came right off. YRMV
    rusty valley likes this.
  10. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Man, 0000 steel wool and some gl*** cleaner, gets all surface containments off and works perfect on gl*** and stainless trim etc.
    blowby, HSF and gimpyshotrods like this.
  11. guthriesmith
    guthriesmith
    If you use razor blades, just be sure they are new and you might use 2 or 3 to keep them that way. I have never scratched gl*** as long as razor blades were sharp.
  12. It's what professional detailers and body guys use. I learned it from a good friend after the previous snafu.
    mad mikey likes this.
  13. gimpyshotrods
    gimpyshotrods
    I use 0000 steel wool and gl*** cleaner.
  14. jaracer
    jaracer
    A buddy of mine ran a heavy truck body shop and also built about one custom car a year. He also did custom upholstery. Lacquer thinner was his go to cleaner for everything. He washed his hands in it most days before he went to the tavern (attached to the body shop).
  15. guthriesmith
    guthriesmith
    Lol...yea, my kids will even tell you that it is good to clean your hands with lacquer thinner...bad on me for that one. :oops:
  16. I may or may not have had lacquer out cleaning my hands yesterday...................................But, I would still use the clay bar on gl*** after trying it
  17. guthriesmith
    guthriesmith
    I know I used lacquer thinner to clean a paint gun and my hands yesterday...
    But, I would still use razor blades for this problem. :p
    hotrodjack33 and Tman like this.
  18. hotrodjack33
    hotrodjack33
    I am always using lacquer thinner to clean my hands...only used a razor blade to clean them ONCE:eek::(
    blowby and guthriesmith like this.
  19. jimmy six
    jimmy six
    Going to the tavern was just a continuation of a day in a paint shop. Never knew who didn’t. Most are no longer with us…
  20. jaracer
    jaracer
    He only had to walk through the kitchen to get to the tavern. Also no longer with us, I think he was 81. Sloans Tavern.jpg
  21. twenty8
    twenty8
    When using razor blades on gl***, use a spray bottle with some soapy water as well. Don't need much. Just enough to lubricate the process a little.
    blowby, X-cpe, Squablow and 2 others like this.
  22. Gl*** is impervious to paint. Gl*** is "harder" than paint so s****e it off and use rubbing compound to polish off any residue. Razor blades are "harder" than gl*** but you would have to be a total putz to scratch the gl***. Just ask yourself if you're a 'total putz' or not.
  23. mad mikey
    mad mikey
    Not rocket science, If you are not satisfied after the razor cleaning, get some gl*** polish from the Eastwood Company and polish the gl***. It will look great and be super smooth,
    blowby and Tow Truck Tom like this.
  24. 210superair
    210superair
    from Michigan
    Fibergl*** oxidation remover works as well.
    blowby likes this.
  25. gene-koning
    gene-koning
    Razor blades with a little water are the cheapest way to remove overspray from gl***.
    Like most chemicals that used to work well, what they call lacquer thinner these days isn't anywhere as good as the stuff from a few years ago. Its probably better to use for your hand cleaning then the old stuff was though.
    mad mikey, blowby and guthriesmith like this.
  26. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    I use razor blades for lots of things, including removing stubborn bug splats from the windshield. Be sure the gl*** is clean and the blade is sharp with no nicks. I've never scratched the gl*** doing this.
    Get yourself a single edge razor blade s****er and a pack of blades and you're good to go.
    blowby likes this.
  27. And soak it with gl*** cleaner. Helps prevent the scratches ;)
  28. Squablow
    Squablow
    Clean, new razor blades, doesn't hurt to spritz a little Windex on there first to lube the blade. I would not want to put any chemicals or thinner real close to my fresh primer or paint for fear of loosening it up.
  29. F-head
    F-head
    Worked in an auto gl*** shop years ago
    Every new windshield was submitted to a new single edge razor blade, sprayway gl*** cleaner then 4 ot steel wool and gl*** cleaner
    blowby likes this.
