P-38 Bellytank update 2005
Discussion in 'The Hokey Ass Message Board' started by Bobby Green, Nov 4, 2005.
  1. Bobby Green
    Bobby Green
    Well, Here is my yearly Hamb update pics on the Bonneville project. It's been a long and complicated build, but it looks like I'll be racing next year, the 4 banger motor is being built right now, and should be ready to drop in in a few months. The head fairing was finished last week by my buddy Jeb, he is a metal shaping master. Notice the nice riveted detail on the front.
    Enjoy the pics.
  2. Evilfordcoupe™
    Evilfordcoupe™
    AWESOME!!!!!!
  3. 2manybillz
    2manybillz
    Nothing but beautiful, I'm in awe!!!
  4. Derek Mitchell
    Derek Mitchell
    Talk about motivation to go get mine. :D
    Damn nice work.
    Spent, I'm on my way....
  5. 1940rpu
    1940rpu
    Man that is a piece of artwork! Good luck with the racing on the salt. Has anybody ever built a belly tanker for the street?
  6. Evel
    Evel
    1. 60s Show Rods
  7. Chaz
    Chaz
    Killer !!!!! Got a close photo and an explanation on the front end suspension?
  8. fatassbuick
    fatassbuick
    from Kentucky
    Without a doubt, the coolest HAMB build ever.
  9. Django
    Django
    from Chicago
    Evel, I hope you've been documenting this...
    Wow.
  10. Bigcheese327
    Bigcheese327
    Yes, somewhere I've seen a picture of a drop tank with a windshield, mirrors, lights etc. It had Ford wire wheels and looked like it was done in the late-40s or early-50s. It was front-engined and the driver sat up a lot higher than on a lakester, but it was still pretty cool. The real challenge would be getting it titled and registered.
  11. Wow! :cool: You are going to have a killer setup with your A roadster, Indy trailer and Belly Tanker!
  12. Very nice man, thanks for the update. Any details on the 4 banger?
  13. Byron Crump
    Byron Crump
    Bobby, can you check you PM's...
  14. Bobby Green
    Bobby Green
    Chaz,
    Here is the front end. The axle is straight obviously, Ford spindles, shortened 32 spring. the shocks are Armstrong, used on early MG's, they were popular for hotrods because you can change the pressure by changing the weight of oil inside them. I ran mine upside down, and had to put a small reservoir on top to keep air bubbles out of the valve. The steering box is from an old dragster, there is a steering dampner attached, and the brake pedal is a modified GM master cylinder from a sprint car. Gas pedal is from an old race boat and is hydaulic.
  15. bluebrian
    bluebrian
    from dallas
    thats the most badass thing i have ever seen...
    where do i get a belly tank...?
  16. Bobby, Nice work man! There are some of us that are paying attention to this and I am one of them. I will check it out at B-ville next year.
  17. scorchr
    scorchr
    BAD ASS! I love belly tanks. This one is sweet! See you on the salt.
  18. johnny bondo
    johnny bondo
    from illinois
    nice man. i love the sheet metal work.
    keep it posted, one fo the coolest builds ive seen.
    JR
  19. SinisterCustom
    SinisterCustom
    AWESOME Bobby!!! Looks like a whole lotta FUN!!!
    I like your wheels! :D
    Josh
  20. fur biscuit
    fur biscuit
    so purdy. the workmaship looks great, look forward to seeing more pictures.
  21. fab32
    fab32
    That's truly some impressive work. What class are you building for?
    Frank
  22. FORDY 6
    FORDY 6
    OUTSTANDING! I'd like to see it run...
  23. Slag Kustom
    Slag Kustom
    I have been working on a design to use a vw transaxle and flat head V8 with a dropped beam front end and hairpins front and rear for the street. most is figured out on paper just need the time to build it. thinking of cantalever rear coil overs to hide them inside the body. It should look right and have all the functions to work on the street
  24. Great work.
    Can I ask a couple of q's..., did you change the ratio of the steering box ?
    Also what type trans. and rear gear ratio ?
    Are those the tries you're going to run ? what size are they ?
    Good luck, very cool :)
  25. Bobby Green
    Bobby Green
    Roost, No, I haven't changes the steering ratio. The trans is going to be a shortned c4, and the rear in a quickchange, were gonna start with a 3.25-3.50 ratio and change from there. The tires are 18's
  26. hemi coupe
    hemi coupe
    from so-cal
    That thing is killer, the craftsmanship is top notch.
    Jimmy White
  27. Squablow
    Squablow
    So, what is this "4 banger" motor you're building? Is it an A/B block, or an OHV? Inquiring minds want to know.
  28. gowjobs
    gowjobs
    If you're going to use a VW trans with hairpins (I'm assuming swing axle), why not run a transverse A or T spring over the top of the trans? Check out your ride height... if you need it to be lower, I've seen sand drag cars with the transaxle flipped upside-down to lower the crankshaft in relation to the axle centerline(by about 4").
  29. Bobby Green
    Bobby Green
    OK ok, I didn't want to reveal too much info, but I guess I can give up a few juicy details. Model B, SOC Hal head, full pressure oil, with or without 5 main crank and girdle, were still working on getting a good align bore, and were Blowing it.......the induction I mean. LOL Carbs for now, maybe fuel injection later when the funds are there.
  30. Slag Kustom
    Slag Kustom
    thought of the transverse spring with the swing axle but had planed to use the motor plate and trans case as the end of the frame. I want to keep it as light as i can. Even though it will be a street car
