Technical P/U Bed ID needed
Discussion in 'The Hokey Ass Message Board' started by scotts52, May 8, 2025.
  1. scotts52
    scotts52
    Hoping to ID this pickup bed. Has a Ford banjo under it but I don't think the bed is Ford. IMG_20250508_171334_383.jpg IMG_20250508_171345_343.jpg IMG_20250508_171354_003.jpg
  2. Looks like 30s to early 50s gm bed
    Gms had this styling till around 53
    the fender mounting area looks like an earlier version unless it’s been messed with
    scotts52 likes this.
  3. No name tailgate suggest 37-38
    Unless it’s skinned over
  4. 2deuces64
    2deuces64
    What does the bed floor look like? If it has wide ribs ( 2-2.5" ) it could be a 36-38 dodge
    anthony myrick likes this.
  5. Hmmmmm
    dodge bed
    detail is different though
    2deuces64 likes this.
  6. Those old chrome slots are the bees knees.
    lucky
  7. scotts52
    scotts52
    Tailgate has been messed with. It's either been framed in with angle iron or changed out completely.
  8. scotts52
    scotts52
    It's got a skin of sheet metal over the whole interior. It's full of garbage right now so can't really get a picture to show it.
  9. Hmmm
    what kinda bones
  10. gene-koning
    gene-koning
    The tail gate could be home made. The tailgate with the tubing down the center probably was not an auto factory item.
    The corner braces will probably give away the original manufacturer better then anything else, but its pretty obvious to me the bed has been modified, so who knows how much of what we see is original to any brand?
    This bed and tailgate are completely custom built. Other then the rear fenders, no real truck bed or bed parts were damaged in this pursuit.
  11. 1biggun
    1biggun
    That was my guess.
    Reminded me of my 37 Dodge
  12. 51504bat
    51504bat
    Studebaker? Looks almost factory on my '39 p/u:cool: IMG_20250508_192651937.jpg IMG_20250508_192704518.jpg
    swade41 likes this.
  13. swade41
    swade41
    from Buffalo,NY
    Looks similar to the Studebaker bed I used on my chevy
    And how a stock 41 chevy stake pocket looks on the left (modified chevy on right), you can see the Studebaker is much tighter to bed side
    51504bat and saltflats like this.
  14. scotts52
    scotts52
    The tailgate is framed in with small angle iron. I've highlighted it in this picture. IMG_20250508_171334_383~2.jpg
  15. gene-koning
    gene-koning
    Either way, most likely, that top tail gate "rail" would have been a round tube, and the bottom "rail" could have been a round tube, or a square tube with rounded corners (Dodge used this). The tailgates were often bent because heavy stuff was loaded onto them to be pushed into the bed, removing the tubes and replacing them with angle was pretty a standard procedure. Sometimes that angle was pretty thick stuff.
    The angle iron side "rails" were pretty standard from the auto companies.
