Projects Packard 352 questions.
Discussion in 'The Hokey Ass Message Board' started by Donuts & Peelouts, Nov 5, 2017.
  1. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Alright thanks for clearing that up for me. It won't make a difference just like you said. That's cool you don't mess with automatics. I would prefer a manual trans. The toploader 3 speed I can get my hands on next time I get paid is from "64 to 72", is that a good candidate?
    Someone on the Packard forum told me my moter was not a Packard engine but rather a Clipper engine. Do you know what that's about?
    Sent from my SM-J727T1 using The H.A.M.B. mobile app
  2. RichFox
    RichFox
    Don't worry about what he said. It's a Packard weather it came in a Packard 400 or a Clipper or a Hudson or a Studebaker Golden Hawk. People get all in a bunch about small stuff. Yes the trans you can get is a good choice
    Donuts & Peelouts likes this.
  3. zzford
    zzford
  4. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
  5. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Ok thanks. Wow, I'm gonna go ahead purchase that first being I can get it for 80$ with the linkage, bellhousing, and clutch. I didn't know it was a good candidate. I know people like 4speeds. But I don't care as long as I'M shifting.
  6. zzford
    zzford
    Huh.....I thought clipper were powered by sails.
  7. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    At this point mine is. Lol
    VANDENPLAS likes this.
  8. wryhawk
    wryhawk
    Jack Vines is the Packard guru you seek. He posts here, and in the Studebaker club form.
  9. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    I've been in contact with him, real nice and helpful guy.
  10. Squablow
    Squablow
    If you get that engine running and the trans turns out to be good, I'd just run it. Sure stick is nice, but the Ultramatic shifts nice and is a good trans as long as everything is working properly. Sounds like you're on a budget and the trans swap is going to be pricey and involved, I don't think I'd start buying up parts for a trans swap until I knew that original trans was shot.
    Hnstray and Donuts & Peelouts like this.
  11. I suppose you could make an aluminum plate that bolts to the back of the block, and then trim away a GM case to where you could weld the two together at the proper length and centerline. Not a cheap or easy proposition.
    Don't forget. Then you'd have to "adapt" the torque converter, flex plate, and starter.
    Bearcat_V8 and Donuts & Peelouts like this.
  12. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Good point.
    I'm gonna need the shift linkage that connects up to the engine from the ultramatic though because mine is missing.
  13. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Would that after welding be bonded forever?
  14. ?
    Not following you .
  15. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Sorry I was asking if after you weld the transmission to the aluminum plate will they be bonded as one unit and unserviceable
  16. The plate would BOLT to the engine.
  17. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Got it thanks Mark.
  18. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Thanks for everyone's help and comments. Sorry for not relying but I have alot of research I need to do after all the suggestions I received. Once I can I will formulate more questions. Thanks alot guys.
  19. Odins parkhard
    Odins parkhard
    If u have the ultramarine trans and it's whole. The linkage is a bit complex but I have one together and can send u pics. Those transmissions from 51-54 packard automatic r very tough. I found affordable source for seal kit as mine leaked. But works purrfect. W just 104000. MI on it n parts needed renewed. I know it was drove very hard indeed.
  20. kidcampbell71
    kidcampbell71
    Jack Vines is @PackardV8 by the way. He builds some wicked *** Packard engines.
  21. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Yes please ill pm you my contact
  22. Odins parkhard
    Odins parkhard
    Please send contact info again , I'll dig up the company info for your trans kit. Apologies for not getting back to you sooner .
  23. Odins parkhard
    Odins parkhard
    Oh an curse my big fingers, ultramatic.
  24. Rusty O'Toole
    Rusty O'Toole
    MT = manual trans not Mickey Thompson. Packard made manual trans available with that engine so, the best and cheapest way to go would be to buy the Packard bellhousing clutch etc and use that. Also a used distributor. There are electronic ignition conversions from Pertronix or you can use a Ford thick film ignition module with the stock points.
    The parts you want are not very rare or hard to find in Packard circles. Here is where you find the real gone Packard fans, they can help you.
    Packard Motor Car Information - Packard Forums
