Technical Packard 6v to 12v
Discussion in 'The Hokey Ass Message Board' started by ponchomike, Mar 14, 2023.
  1. ponchomike
    ponchomike
    Hello all, I need a little help. If I am supplying all parts, how much should I expect to pay for labor to convert 6v 1939 Packard to 12v.? Thanks.
  2. BJR
    BJR
    Moving target. Labor rate + materials. Depends on how bad the wiring in the car is to start. Is a kit available? Or do all the brackets need to be fabbed?
  3. hemihotrod66
    hemihotrod66
    It was easy to run 6 volt stuff back when the cell connectors on the battery were exposed...We would measure voltage across the cells of a 12 volt battery and tap the 6 volt side and use that for 6 volt accessories like gauges and lights but use the 12 volts to start and have 12 volt generators...Now they are all sealed....
  4. brading
    brading
    We can get that type of battery over here so would have thought that you could over there.
  5. brading
    brading
    You could Google Cl***ic Car Batteries as I would have thought there is market for this type of battery from the Cl***ic car guys over there.
  6. theHIGHLANDER
    theHIGHLANDER
    What is the reason, is the car modified? I've serviced and restored countless Packards and never advised 12V conversion. Shim the pole shoes closer the armature, clean the armature body real good, file the mica down from the commutator bars, it'll spin over like being jump started.
    1952henry likes this.
  7. v8flat44
    v8flat44
    Clean, clean all connections, specially ground connections. New proper size [gauge] cables & what theHIGHLANDER said
  8. Budget36
    Budget36
    Maybe ask why to change to 12v might be in order, not how to keep 6v.
    Personally I don’t have a working 6v charger anymore, I really don’t want to buy one.
    Maybe the OP wants a bit of comforts that 12v can provide? Ie sound system, better lighting, maybe road side help for a jump start?
    The HAMB still modifies vehicles I think.
    firstinsteele likes this.
  9. theHIGHLANDER
    theHIGHLANDER
    "What is the reason, is the car modified?"
    Just sayin...
  10. sunbeam
    sunbeam
    If the wiring is original the insulation 84 years old
  11. 5window
    5window
    If you just need help starting,maybe go to an 8V battery?
  12. Mike, you opened a can of worms!! One would think this is AACA instead of the HAMB!!
    I probably only spent a couple of hours doing my 1950 Buick. It is a SIMPLE chore. Mounting an alternator can be a chore. A 12V generator would be easier if output is enough for you. Chang all the bulbs. Wire is ample size. 12v wire is smaller.
    Bring it on over. After we are finished, you buy dinner. Done
    Ben
    5window likes this.
