Packard Engine interchange help!!!
Discussion in 'The Hokey Ass Message Board' started by slowwrench, Aug 30, 2010.
  1. I have a 54 with a 359 and Gear Start auto trans. Will a 49 327 from manual trans car bolt in?
    Thanks
    Keith
  2. v8packard
    v8packard
    from IL
    The '49 engine used a front yoke mount, the '54 has side mounts on the block. If the 327 has the holes in the side of the block for the mounts, you could use the block with the '54 mounts. The trans is just the opposite: side mounts on the '49, and one center-tail mount on the '54. You would really need a '51-'54 trans.
    Questions - Why do you want to switch, and would you sell the '54 parts?
  3. br-549
    br-549
    from NC
