Technical Packard trans/adaptor/bellhousing question
Discussion in 'The Hokey Ass Message Board' started by 64T-bolt, Apr 14, 2025.
  1. 64T-bolt
    64T-bolt
    from Kansas
    IMG_4374.jpeg IMG_4373.jpeg IMG_4372.jpeg IMG_4369.jpeg IMG_4370.jpeg IMG_4371.jpeg IMG_4368.jpeg I received this packard trans with my model a coupe I’m building. I want to run it behind my ‘40 flathead. It came with Lucas adaptor plate, and the broken bellhousing attached. It also came with the hildebrandt adaptor bell. What should I run? The Lucas plate has a lot more material and fasteners, is steel. If I run it, does anyone know what the broken bellhousing is? Or should I run the aluminum piece, it only attaches with 4 bolts threaded into the aluminum.. I’m kinda new to this flathead game. Is the packard trans a good choice?
  2. gimpyshotrods
    gimpyshotrods
    The black bell is a 4 Speed bellhousing, from a 1935-1952 Ford truck.
    Shown with a GM pattern adapter.
    dana barlow likes this.
  3. gimpyshotrods
    gimpyshotrods
  4. 64T-bolt
    64T-bolt
    from Kansas
    so is this a GM trans or was the Packard trans GM pattern? (Excuse my ignorance)
  5. 64T-bolt
    64T-bolt
    from Kansas
    Would there be any reason to not run the Hildebrandt piece?
  6. warbird1
    warbird1
    If it fits the engine and transmission use it. Just be sure to dial it in to check the alignment before installing the transmission...
    64T-bolt and gimpyshotrods like this.
  7. gimpyshotrods
    gimpyshotrods
    I cannot see enough of the transmission to identify it.
    The position of the shifter tower looks Packard. I think they went to column shifters in about 1939.
    64T-bolt likes this.
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    That's a Packard transmission. The bolt pattern looks similar to a G.M. pattern, but the bolt holes sit lower in relation to the center hole; in other words, it looks like a G.M. pattern that has slid down lower on the bell housing.
    gimpyshotrods and 64T-bolt like this.
