Technical Painless fuse panel WARNING!
Discussion in 'The Hokey Ass Message Board' started by Crazy Steve, Aug 19, 2025.
  1. I kinda hate to post this, but I feel it's important information that members should be aware of. This came to my attention as I was exchanging PMs with another member as he was trying to pick out a fuse panel, with this being one of his choices. There was a fairly recent thread with some melted wires and a melted internal buss in the panel and I think it was this one...
    Universal Style Pre-Wired 20 Circuit Fuse Block Part No 30003 – Painless Performance
    This Painless panel is everything I hate about the aftermarket harness suppliers as it's a far too typical design, although it may be worse than some others. IMO it's a total POS. They don't furnish an internal wiring diagram for it, but if you read the instruction directions you can figure out its limitations (many). A few highlights from their 'manual'...
    Item 9. If you have an alternator with an output of more than 65 amps, they want you to add another wire between the alternator and the battery or solenoid. First, connecting the alternator output to the panel is a bad idea for multiple reasons and adding this second wire only compounds it, which I have gone into in other threads. Basically they're admitting that this panel can't handle any loads beyond this amount without damage to it. I'll explain why this connection to the panel is there further down
    Item 10. This panel is internally split, but ALL of your key-switched loads go through this #12 wire. Properly derated, this limits you to 16 amps for all of them.
    Item 30. This wire is supposed to supply ALL power to the panel, although that's really not true. Being a #10, if properly derated its only good for 24 amps. Note that they 'strongly recommend' that it be fused at 50 amps at the battery/solenoid. But ***uming the 50 amps is available, that means your average circuit size is limited to a mere 2.8 amps each if using all fuses. This is actually only a 18 circuit panel, that's how many fuses it has. So that means that some relays are in your future. Likely candidates are headlights, fuel pump, heater/AC, and cooling fan. If you have an amplifier for your radio, that's another one. Maybe more, depending on what actual loads are. All of these relays will have their own main power feeds at the battery/solenoid and should be fused at that point... defeating the idea of a unified panel. If your total circuit count is lower, a smaller panel would be a better choice; you're paying for capacity you won't use, although you may still need relays depending on the panel design.
    That wire in item 9? The theory behind this is if the load on the maxifuse (***uming it's present) gets too close to its rating (risking blowing it), this wire (which is UNFUSED) will supply the 'extra' until the load drops back to 'normal' (hopefully quickly). If the fuse does go or you get a poor connection at the fuse terminals or the wire in item 30, ALL of the load will fall on this #12 and a fire along with a damaged fuse panel may ensue...
    If you have one of these wired the way they say, I will highly recommend that you...
    1. Remove both of the wires in item 9.
    2. Install that 50 amp maxifuse if you don't already have one.
    3. Do load calculations for EACH circuit and remove enough of them from the panel (feeding them through relays with separate power supplies) to drop total connected load to below 50 amps. You can use the existing circuits in the panel to switch the relays or simply gang the relay coil power to any switched hot.
  2. A bump for visibility...
  3. saltflats
    saltflats
    from Missouri
    I tend to use a lot of relays doing a wire harness.
    TrailerTrashToo likes this.
  4. RodStRace
    RodStRace
    @Crazy Steve Thanks for this. Chrysler (and others) loved the amp gauge to have all the load go through it and the bulkhead connector. It has over time proven to be a hazard.
    I know you have addressed this in previous threads, but when you say to do load calculations, providing a source for this that can be used by the widest cross section would be helpful. I replied to another wiring question and found widely different numbers.
    https://www.jalopyjournal.com/forum...and-wiring-info.1120201/page-30#post-15673293
    6inarow and pprather like this.
  5. Ziggster
    Ziggster
    Interesting. In my mind, it seemed most folks were happy with them and recall seeing many recommendations. Do you know what kind of wire they use? Back in the day, for all of our mobile HVAC wiring products , I think I spec’d out SXL?.
  6. d2_willys
    d2_willys
    from Kansas
    This panel should have maximum total current being drawn specification listed and is a warning for the customer.
    6inarow likes this.
  7. alchemy
    alchemy
    Steve, what is your favorite brand of aftermarket wiring panel/kit? Something simple like most HAMBers would need without a couple dozen circuits for modern conveniences?
  8. e1956v
    e1956v
    Alliance Vendor
    Great heads up. Not worth trying to save money and end up burning your car up.
    Bandit Billy likes this.
  9. 6inarow
    6inarow
    EXACTLY. and it should have it spelled out for each circuit. The descriptions and specifications for most panels I have seen ****. This entire wiring thing is hard enough to do right without having to figure out their hidden shortcomings. To me it seems these wiring companies spend more time trying to sell us what they want to sell rather than what we want to buy.
    I am going to plan my wiring job out and then see what panel works best for me.
    williebill likes this.
  10. To be honest, I have yet to see one I'd buy. I'll build my own...
  11. downlojoe33
    downlojoe33
    For the $ they get for their wiring panels, you’d think the short***ings would all be worked out.
    5window and 6inarow like this.
  12. nosford
    nosford
    What is even more to add to this is the length of time that is acceptable for a fuse to open (blow) according to the SAE standard.
    The response time of a standard SAE automotive fuse (like those found in cars) varies depending on the current flowing through it, but it generally falls within a range of 0.75 seconds to 120 seconds at 135% of its rated current according to State Electric Supply Company and Circuit Spe******ts. At higher currents (e.g., 200% of the rated current), the opening time decreases significantly, potentially ranging from 0.15 seconds to 5 seconds, according to Circuit Spe******ts.
    Here's a more detailed breakdown:
    • At 110% of rated current:
      The fuse should be able to carry this current continuously for at least 100 hours according to Circuit Spe******ts.
    • At 135% of rated current:
      The fuse should open in no less than 0.75 seconds and no more than 1800 seconds (30 minutes) according to Circuit Spe******ts.
    • At 200% of rated current:
      The fuse should open in not less than 0.15 seconds and no more than 5 seconds according to Circuit Spe******ts.
    • At 350% of rated current:
      The fuse should open in not less than 0.08 seconds and no more than 0.50 seconds according to Circuit Spe******ts.
    The exact opening time for a specific fuse at a given current can be found in the fuse's time-current characteristic curve, which is often provided by the manufacturer. These curves show how long it takes for a fuse to open at different current levels according to Littelfuse.
    So, there was a fuse recall from Harbor Freight several years ago that was a kit of 60 fuses of varying sizes. They would not blow at all! A 20 amp fuse being hit with 60 amps melted the plastic off but did not open after 15 minutes! Beware cheap fuses from unknown manufactures from whatever source on line you choose!
    GuyW and 6inarow like this.
  13. brigrat
    brigrat
    from Wa.St.
    I haven't used Painless in years, it was one of the first aftermarket panel kits back in the day. Now it's just American Auto Wire or a DIY job.........................
    milwscruffy likes this.
  14. Rice n Beans Garage
    Rice n Beans Garage
    Crazy Steve, I appreciate the information you share and your advice on wiring. My Father specialized in building wiring systems for older vehicles, I wish I could have remembered all that he taught me, your comments stay true to his knowledge.
    Kits are kits, some people seem to think if it functions it’s correct, not always the case.
    6inarow likes this.
  15. GuyW
    GuyW
    This thread made me think about Tom McMullen who initially started a company doing automotive wiring (AEE). I wonder whether he abandoned that line upon finding that not enough people were willing to pay adequately for a competent wiring job (I'm ***uming McMullen did competent work).
    6inarow and RodStRace like this.
  16. RodStRace
    RodStRace
  17. downlojoe33
    downlojoe33
    I remember seeing in Street Rodder when he was building his mul***ude of 32s, some pictures of his wiring prowess. If he was actually doing the work, the design looked very well laid out and pretty. No idea about the functionality of it all, but he did drive his cars.
    GuyW likes this.
  18. GuyW
    GuyW
    Tom was an electronics tech before he started his businesses...
    downlojoe33 likes this.
