Has anyone ever used Squeeg's Customs Top Coat suede primer. It's an epoxy primer with color added. You are supposed to be able to run this for two years protecting the car, then you can sand and top coat then clear. This would be perfect for my 31 A project. The car is driving, but I want to run some , get the bugs out, then decide if I want to chop top. I have sprayed the car with epoxy and with 2k urethane primer. I tried a test panel with Flatz and the stuff almost put be out. Had respirator on and was in an open end of my make shift paint booth with exhaust box fans. Hoping someone can tell me a little about the Squegg's Top Coat.
