Paint Advise Needed
Discussion in 'The Hokey Ass Message Board' started by Bigimp62, Jun 24, 2009.
  1. Bigimp62
    Bigimp62
    from SoCal
    Hey All,
    So I've been on this board for a little while now just soaking up the info and have to say it's been great! I have a question about paint though. I am getting ready to paint my '62 Imperial and am going to do a flat white paint job with a gloss metallic green top. I've read and heard that you can spray just a base coat of a base clear coat system for that flat/satin look. My question is will the regular base coat alone stand up to UV light and is it durable enough to stand alone?
    Thanks in advance,
    CC
    '62 Imp
  2. Special Ed
    Special Ed
    No. Add a flattening agent to your topcoat of clear.
    Why not be traditional and paint it glossy?
  3. paintslinger
    paintslinger
    from Kemah, Tx
  4. brandon
    brandon
    i couldn't imagine owning a flat white car....it would end up being a greasy , painted hand printed pos ....:D i guess you could clean it with a magic eraser though.....:rolleyes:
  5. OshkoshRob
    OshkoshRob
    from Oshkosh
    The UV protection is in the clear on a base/clear paint system.
  6. skullhat
    skullhat
    i agree, base coats without clear dont hold up too well. ive tried ppg deltron 2000 with hardner and flatening agent, but it wasnt all that great.
    if you can get ppg's flexed and flat clear where you are, that works great. pcl also has a version.
    skull
  7. rick finch
    rick finch
    ...flat white? ah, no!!!
  8. Painter D
    Painter D
    from DFW
    Nope ,you need some clear on top of the base. As suggested already.
  9. millersgarage
    millersgarage
    so as you can see from the above, you need a clear coat. A flattening agent can be added to a single stage paint too, eliminating the need for a 2 stage finish.
    I also agree, that flat white would be a pain to keep nice. There are many stages to a "flat" finish. Go with 80% or so, just to cut the shine out, but still have the ease of cleaning.
  10. Nick
    Nick
    My buddy had a flat white car once. It was shiny at one point. Apparently if every time you wash it you scrub it with comet to get the greasy hand prints off turned it will turn flat.
  11. Grashopr
    Grashopr
    from Kansas
    The Hot Rod Flatz are nice, spray well, but if you're wanting to do it with urethane and make 100% sure it's fuel-safe, spray the car white, then instead of using a flattening agent in clear (which will 100% guaranteed end up chalking up on you eventually), mix Doupont DBC-500 4:4:1 with reducer and DCX-61 hardener. Spray this out of a gun with the volume turned down a bit and the pressure turned up a bit and you can 'mist' it to whatever sheen you want. When it dries (takes as long as regular urethane clear), it's washable, fuel-safe and you wont scratch it as easily.
    DBC-500 and DCX-61 are cheap.... if you've got the time, try it. It works.
  12. 31aBoy
    31aBoy
    dbc and dcx are PPG products...
  13. SlowandLow63
    SlowandLow63
    from Central NJ
    Hot Rod Flatz is urethane. And I don't know about using binder as a topcoat...
  14. 29ron
    29ron
    I thought the hot rod flatz had the UV protrctant in the paint and a clear coat was not needed?
  15. Retro Jim
    Retro Jim
    Man don't do that to a great cl***ic like that with a flat white !
    Why not paint it the nice shinny color it was originally ? Those were some really beautiful cars ! Just a thought ! :cool:
  16. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    Flat white?
    How about Sears weather-beater? A friend in HS had a '64 Bonneville that his parents painted with Gray weather-beater as a B-day present to him. It was flat gray alright. Looked like S--t.
    Thought about a pearl white (that's shiney) along with the green top?
  17. ArtGeco
    ArtGeco
    from Miami
    Spray it with Rustoleum Satin White.
    Add a lil' acetone to thin it. At $25 a gallon
    you can't go wrong. It's super easy to shoot.
  18. niceguyede
    niceguyede
    from dallas
    I had an old ford that was flat white, it was the faded factory paint. Well, most of it was flat white, the tops of the fenders and header panel were grease color!! haha!! As others have said, why flat white? Maybe a satin or low gloss, but flat won't be very appealing after a week or two on the road.
  19. newstranger
    newstranger
    I did a roof in White DP (epoxy sealer)... greasy-*** smudges everywhere.
    Pick another color or put some kind of clearcoat over it.
    -ns
  20. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Another no Flattening agent in clear I've heard base is pourous. Im gonna ask you why flat white, Dull looking in my opinion. Gloss .
  21. ArtGeco
    ArtGeco
    from Miami
    You could do the interior yellow and
    it'd look like a hard boiled egg.
  22. skullhat
    skullhat
    agreed, also dbc 500 isnt gonna hold up to well as a top coat, it needs to be cleared as well . we use it as a mid coat clear with candy, flakes , etc....
    skull
  23. 49ratfink
    49ratfink
    if I ever want to paint something flat I'm going with rustoleum.
    as for the base coat no clear idea... what happens... does it fade quickly? I ask because I'm thinking what would flat white base look like after it faded? flat white.
  24. SlowandLow63
    SlowandLow63
    from Central NJ
    Flat white with rust speckles coming through. :eek:
  25. Frankie47
    Frankie47
    from omaha ne.
    Used to be shiny...don't think I like the flat look.
  26. sik_kreations
    sik_kreations
    dcx 61 is cheap? dont think so.
    by the time u bought enuff dbc 500 to coat a car with a couple coats, with dt reducer, and catalyst. ur more then the 120 bucks or so it would be for the hotrodflatz.
    not to mention there is no uv protection in dbc 500. u will have a catalyzed intercoat. but ur supposed to catalyze dbc with dx57 anyway.
  27. sik_kreations
    sik_kreations
    your best bet would be, paint the car white and green. spray gloss clear. color sand and buff roof. sand sides to be recleared, then mix a flat clear using the clear you used to clear the entire ride. mix flattner in it. spray one nice even coat. or 2 if u cant do 1 nice coat. u have the uv protection of the gloss clear with a piss coat of flat clear over it for gloss reduction. plus u can go back and sand off all the flat and reshoot gloss clear if u wanted to get rid of the flat look.
  28. skullhat
    skullhat
    thats good advice. also that method will make for a clean top coat that you dont always wind up with after many coats of various materials.
