paint color
Discussion in 'The Hokey Ass Message Board' started by tpw35, Jun 18, 2008.
  1. tpw35
    tpw35
    Has anyone ever had a paint store add a color to an existing paint to change it, I have a gallon of heavy flake silver that was used on a tag heuer air plane a few years back, The paint is still good and I dont want to throw it out. I would like to end up with a blue metalflake. It is a laquer base paint.
  2. My first thought is to coat what you want w/ the heavy silver flake, let fully cure, then level it w/ 400-600 wetsand & coat it all w/ a blue candy until you get the depth you want. Let that flash & soak it all in the clear of your choice, wetsand it until it looks like a mirror & polish the snot out of it.
    But if it's Lacquer based, I'm not too sure on whether this is an option, or not.
    Somebody here on the board will add to, or set you/us straight on what can & can't be done in this situation.
    Best of luck with it.
  3. brandon
    brandon
    if you can find a supplier for the same type and brand of paint , might try it....add some transparent blue toner...worse case, if it doesn't work, you're only out the toner. brandon
  4. SlowandLow63
    SlowandLow63
    from Central NJ
    I'm not 100% sure, but I think there are still some lacquer candies still around. I do however know for a fact that laying a modern urethane candy over lacquer will lead to a sad face. The lacquer will shrink and wrinkle the candy and whatever clear is over it.
    As far as someone tinting the lacquer to blue, doubtful at best since I don't know of a current paint manufacturer selling lacquers. Unless you can find an old stogey totin bodyman that runs a paint store, you might be out of luck.
    My .02 - Start fresh and avoid the headaches with modern products that function 1000x better than lacquers.
  5. henry29
    henry29
    I mix all my leftover paints all the time.
    What brand is it you have?
    I'd stick with the same brand.
  6. tpw35
    tpw35
    I looked at the can last night, it is pratt & lambert, duro-glo and it is polyurathane, not laquer.
  7. SlowandLow63
    SlowandLow63
    from Central NJ
    Then it can most likely be tinted. However, it might be tough finding a paint store that doesn't carry it to mix it with their materials. You might be better off tinting it with candy on your own.
  8. tpw35
    tpw35
    So would I pour the candy in it or shoot it over the silver?
  9. BISHOP
    BISHOP
    Save the silver flake for a job you would want to be silver flake. You probably wont be able to get it dark enough just by adding toner, you would have to add alot of toner to get past light blue, unless you want light blue. Your gona end up with two or three quarts of toner, pluss the gallon of silver flake, thats almost two gallons of paint before reducer. And who knows what else you may have to add to it to make it like you want. I would get a color picked out of a book that has a paint code, you never know when your gona need to reshoot somthing. I think your best bet is dont be messin with the silver at all.
  10. Shifty Shifterton
    Shifty Shifterton
    ^^^^^ pretty much what he said
    If you've ever mixed with silver base it takes a TON of other color to generate significant shift in tone. I'd be tempted to basecoat with what you got and topcoat in a candy to establish tone.
  11. SlowandLow63
    SlowandLow63
    from Central NJ
    Either will work. I think you'll have better results with shooting the candy over it as these guys have mentioned.
