Technical Paint Compatability
Discussion in 'The Hokey Ass Message Board' started by Scott, Feb 18, 2023.
  1. Scott
    Scott
    Can I paint over an acrylic urethane single stage with a clear urethane
    Im doing a partial metal flake over a single stage acrylic urethane
    as always thank you HAMB
    @vickywithahemi
  2. theHIGHLANDER
    theHIGHLANDER
    Yes. Don't sand it to aggressive, I'd say 600 grit is the roughest. 800 would be better.
  3. Scott
    Scott
    Thank you Highlander
    theHIGHLANDER likes this.
  4. BJR
    BJR
    Did the base paint have catalyst in it?
  5. You’re probably good on an older paint job.
    If worried, test a small area on the car.
    bobss396 likes this.
  6. crider
    crider
    As long as the base color was properly applied and hardener was used you should be fine. Sand it with 800 grit and go for it
  7. Dustin 257
    Dustin 257
    from Dallas
    Just a question, why should the base matter if the urethane clear has held on good? Unless he bust threw the clear then the base would matter?
  8. ronzmtrwrx
    ronzmtrwrx
    He said it was a single stage urethane, so there is no clear on it presently.
  9. theHIGHLANDER
    theHIGHLANDER
    Let's aliviate some concerns. If it's a urethane of any kind it needed a catalyst/hardener to cure. That's been standard fare since the early 80s. Scuff n shoot. You're ½ ready to go already, asked the right question...;)
    Desoto291Hemi and 31Apickup like this.
  10. Dustin 257
    Dustin 257
    from Dallas
    My bad. I read it wrong. Thanks
  11. ronzmtrwrx
    ronzmtrwrx
    Hahaa. No problem. I do that quite often myself.
