Technical Paint Fix
Discussion in 'Traditional Customs' started by PeggySue, Sep 27, 2022.
  1. overspray
    overspray
    PeggySue likes this.
  2. PeggySue
    PeggySue
    Think that maybe above my skills
  3. PeggySue
    PeggySue
  4. Bandit Billy
    Bandit Billy
    As you reach the upper end of the temp range on the activator it is hard to keep the edge wet. Medium activator is 70-80 f. Even 80 f starts to develop issues, high 80's require slow activator and that means the temp on the parts as well as ambient shop temp. I just went through this issue on my truck. Painting is more science than I care to admit...and dammit I'm a mortgage guy not a car painter!
    I would scuff that paint on the roof with 600 to ensure a mechanical bond, match the activator to your shop and parts temp using a IR thermometer and reshoot the top.
    anthony myrick and PeggySue like this.
  5. PeggySue
    PeggySue
    Thanks..If I go to slower activator does it have to be same paint brand??, if I remember they didn't have slower one or they were out
  6. PeggySue
    PeggySue
    This is the data sheet if you can open, I see they do make a slow activator for flat
    • x60.pdf
      2.5 MB
  7. Happydaze
    Happydaze
    Might work, might not. General rule is to not mix brands to avoid compatibility issues. If the supplier is out of stock at the moment thats telling you something about whats being used by everyone right now. They shouldn't be out of it for long as they'll be letting their regular customers down.
    Chris
  8. K13
    K13
    Not these days it doesn't there are m***ive supply chain issues (like most industries) in the paint and body industry right now especially on the chemical side of things.
    0NE BAD 51 MERC likes this.
  9. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    You're in Minnestoa, you're going to be in the 60 to 70 mid temp range before you know it! Actually, a day before I do in Wisconsin. lol Larry
    overspray and PeggySue like this.
  10. PeggySue
    PeggySue
    Yep , Have insulated garage but not heated, maybe next spring job. We had frost last night
