Paint Help
Discussion in 'The Hokey Ass Message Board' started by Jim636, Dec 8, 2015.
  1. Jim636
    Jim636
    from Wyandotte
    How's it going out there ? I have been working on this project for a couple of years. Let me get right to the point . I want to paint these flames on my Fleetline.Would this be candy purple over silver ? Thanks for any help.
  2. Stu D Baker
    Stu D Baker
    from Illinois
    Sometimes color resolution looks different from "in person" to "on Screen". I'd start doing some spray out panels until I got the color I liked. Nice car.
  3. Paint Guru
    Paint Guru
    from Bowdon, GA
    Its very hard to tell, since the flames aren't faded just get a silver tinted to the shade you desire and skip the 3 stage.
  4. Jim636
    Jim636
    from Wyandotte
    Thanks for the comments. Of course I tried to paint the car myself and it all came out good except for the streak down the center of the car and its matt paint so not much I can do to fix it. So I figured I would try this flame job to cover it up being I didn't want to respray the whole car over.
  5. Paint Guru
    Paint Guru
    from Bowdon, GA
    Well if you are not going to clear the car after the flame job I definitely would not do a candy job, you will have a hard paint line with the extra layers of paint.
  6. Jim636
    Jim636
    from Wyandotte
    Damn..........Paint Guru any idea on how to get rid of the streak down the center of the car ?
  7. Paint Guru
    Paint Guru
    from Bowdon, GA
    Is it on roof hood and deck lid?
  8. Paint Guru
    Paint Guru
    from Bowdon, GA
    Just do a single stage flame job, I can make that color in a satin finish for you, two coats and done.
  9. Jalopy Joker
    Jalopy Joker
  10. Jim636
    Jim636
    from Wyandotte
    Yes just the roof and deck lid.
  11. Paint Guru
    Paint Guru
    from Bowdon, GA
    Stuff and respray those 2 panels but use the slowest reducer you can get your hands on and do a cross coat on your last coat of paint.
  12. Paint Guru
    Paint Guru
    from Bowdon, GA
  13. Jim636
    Jim636
    from Wyandotte
    Thanks for all the info Paint Guru I'm no painter that's for sure.
  14. Slopok
    Slopok
    Don't blame yourself, flats and satins are tuff for even experienced painters to do without getting tiger stripes.
    Paint Guru likes this.
  15. lodaddyo
    lodaddyo
    Was it hot rod flatz? I had trouble with some of their paint drying like that as well
  16. Jim636
    Jim636
    from Wyandotte
    Kirker hot rod black.....
  17. RogersRodWorx
    RogersRodWorx
    I've used the Kicker hot rod black befor. As mentioned before sand/scuff those panels and re spray them, use a slower reducer, and that should do it.
  18. Jim636
    Jim636
    from Wyandotte
    Thanks guys......
  19. 28TUDOR
    28TUDOR
    If it's a matte paint job, couldn't you just wet sand the car with 2000 or 5000 grit? I used 3000 grit on a bike and it looked good for a flat black. You could try different grit paper to get the sheen you like.
  20. Paint Guru
    Paint Guru
    from Bowdon, GA
    Not really, what gives matte its appearance is a wax paste type product that is in the coating itself and it basically floats to the top surface. When you sand it, it will have a mismatched color, the sheen will match but the shade will be off. This is why matte finishes are NOT recommended for baking because if you don't allow enough time for it to float to the top it will look like a Econo job. Sanding it Might get him by, but you could scuff and tape up those panels in 30 mins and do it right.
  21. 28TUDOR
    28TUDOR
    Ok thanks for the info.
  22. low budget
    low budget
    from Central Ky
  23. Jim636
    Jim636
    from Wyandotte
    Low budget that is what I DIDN'T do. I think it would of helped .
  24. Paint Guru
    Paint Guru
    from Bowdon, GA
    Doing that on the first coat, then cross coat your last coat makes everything nice and uniform, along with slow reducer for matte and satin finishes.
  25. Jim636
    Jim636
    from Wyandotte
    I think I used a medium reducer and the temp was in the mid 70's.......wish I would have known this. Thanks Paint Guru.
