Hot Rods Paint over exhaust pipe welds?
Discussion in 'The Hokey Ass Message Board' started by SDS, Jun 21, 2021.
  1. SDS
    SDS
    I made my exhaust using aluminized steel mandrel bent pipe bends from summit racing and MIG welded everything together. I'm looking for something that is reasonably durable (heat resistant mostly) to paint over the welds - I've done this before and the pipes always rust around the welds.
    Anybody have any suggestions based on experience?
    Thanks!
    Chucky likes this.
  2. oldolds
    oldolds
    Eastwood has a silver paint for manifolds. It holds up well. That should work.
  3. big john d
    big john d
    from ma
    rustoleum barbecue works as well or better than any header paint i have used silver or black outlasts most any of them
  4. rusty rocket
    rusty rocket
    I’ve always painted the whole exhaust system with John Deere muffler black. Whole system usually takes two cans. Can costs about 18-19 bucks so around $40 .
    SPEC and Frankie47 like this.
  5. Elcohaulic
    Elcohaulic
    Any, $4 dollars a can, name brand hi temperature engine pain will do. The Eastwood Iron manifold paint is one of the best. The surface needs to be sand blasted first and make sure you don't touch them any were you want the paint to stick to...
    jimmy six and oldiron 440 like this.
  6. Frankie47
    Frankie47
    from omaha ne.
    Durable and long lasting, I use nothing else.
  7. Hotrodmyk
    Hotrodmyk
    JD muffler black paint sells from $9 to $26 a can!!!! What's the difference?
  8. lippy
    lippy
    from Ks
    Depends on if it goes on a "D" john deere or a 4020. :)
  9. Rusty O'Toole
    Rusty O'Toole
    Years ago I put a new exhaust system on a Dodge pickup and for the hell of it, painted it with some aluminum stove pipe paint I had laying around. Gave it 2 coats. Ten years later the exhaust did not have a speck of rust on it anywhere. The first 2 or 3 feet next to the engine were darkened and discolored but the paint was still on there.
    Black barbecue paint is tough as nails and stands up to heat pretty good, you can get it at any hardware store. You can use what you like, any high temp paint will do. Give the whole system 2 or 3 coats and it will last a long time, if you do not do a lot of stop and go driving. As long as the system gets hot enough to drive out any moisture, it will not rust from the inside and if it is protected it won't rust from the outside.
  10. jimmy six
    jimmy six
    Used BBQ Black on my sons GMC from the cast headers back also on my 39 Indian Sport Scout. Pretty bulletproof. Before and after. The muffler shop coated their welds. 93CCB944-C9E3-4B33-9906-E696D6426A2E.jpeg 60C05F84-9606-43DD-BE22-9CDFEF5C473E.jpeg 1884873A-A1CF-4112-AA6A-85F2F88A54E3.jpeg
    Elcohaulic, 302GMC and Just Gary like this.
  11. Malibu406
    Malibu406
    I used the silver bbq paint based on my research, but have no run time to provide results
  12. TCATTC
    TCATTC
    Header paint
  13. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I know it's more costly but my local powder painter has a satin black he uses on exhaust that holds up real well. I've done a 1/2 dozen cars with it.
  14. Maybe a simple touch-up and you're good to go for another year.
  15. chevyfordman
    chevyfordman
    Use stainless steel wire the next time, it will keep the pipe from rusting.
  16. drptop70ss
    drptop70ss
    from NY
    I wipe down the pipes with cleaner and spray with black 99 cent paint from Home Depot. Lasts indefinitely so far, longest one is a build done in 2011.
  17. deathrowdave
    deathrowdave
    from NKy
    Porter Paint , high temp aluminum . Boiler stack paint , best I have ever used . Stinks like hot piss on a tin roof the first heat up .
  18. You have experience with that?:eek:
    Ben
  19. 1971BB427
    1971BB427
    from Oregon
    I've always used high temp header paint over exhaust welds. At the lower exhaust temps it holds up forever.
  20. SDS
    SDS
    Thanks all
