Paint prep screw up....need some advice
Discussion in 'The Hokey Ass Message Board' started by L. Eckart, Apr 12, 2012.
  1. L. Eckart
    L. Eckart
    I'm in the process of getting my 49 Chevy sedan ready to paint. I skim coated the doors and quarters with filler and block sanded. Then decided to shoot a coat of Evercoat Slick Sand over the areas to take care of any other imperfections. Well, I got in a hurry and forgot to add the hardner to the Slick Sand and didn't discover this until after I shot the stuff on the car. Of course it remained tacky the next day and I realized my mistake. I have razor blade s****ed as much of the Slick Sand off as possible but some residue remains and this is where I need some advice.
    I'm thinking of wiping the areas down with laquer thinner followed by a dry rag but I'm worried about the filler and how the thinner migh affect it. Will I have a problem if I wipe the thinner off the filler quickly? And if I do this should I let the car set a day or so to make sure the thinner has evaporated before I reshoot with Slick Sand (this time with hardner)?
    OR...is there a better method? I don't want the final paint lifting or having other problems. Any help appreciated. Thanks.
  2. pimpin paint
    pimpin paint
    from so cal
    Hey,
    I don't know what you wanna top coat this job with, but it's not worth the gamble...................remove ALL of the Slicksand, reblock the panels with 180, and reshoot with the corrected Slicksand mixture.
    If you attempt to shoot over some of the trapped, uncatilized product, it may well lift once top coated with urethane.:(
    " Life ain't no Disney movie "
  3. hillbilly4008
    hillbilly4008
    from Rome NY
    Man, that ****s. I don't have an answer for you, but I can tell you your not the only one making dumb mistakes like this.
    I used the wrong type of primer on my decklid, then coated it with epoxy. When I went to block sand it came off in sheets...
    I've never heard of this Slicksand stuff
  4. rocketsled59
    rocketsled59
    I think the thinner is the only way to go. I would let the filler air dry out a day after the wipe down. That way the filler can restabilize. Then if there's any damage from the thinner you can glaze it and go on with your slick sand. I guess it's like feather fill? Then you can block reprime and final sand. I've had to wipe down primer and paint and about anything you can think of. It ****s but it happens. Finding the fastest way out of a jam and back on track is what makes you experienced. I'm very experienced. Because I've made many mistakes. You'll get it straightened out. Best of luck! RS59
  5. You can't be the first one, call slicksand tech line. And then call the filler tech line..
    I sure wouldn't risk it, it only gets more expensive and more labor intensive from here.
  6. john worden
    john worden
    from iowa
    I think that as long as you don't flood the filler with thinner and give the thinner time to completely evaporate you will be ok. Couple of days should do it. luck
  7. mashed
    mashed
    from 4077th
    It'll be fine. Wipe it down and allow it to dissapate. I would also re-block as stated above.
  8. Thommyknocker
    Thommyknocker
    from Colorado
    DOH!
    At least I'm not the only one screwing up paint!
    Good luck man
  9. L. Eckart
    L. Eckart
    Thanks for the comments fellows. I feel better already. I will probably also call the tech lines tomorrow as suggested just to see if we all agree. I hate paint problems, especially those I create for myself! Thanks again, I love the HAMB and the quick response from experienced people.
  10. fiddy
    fiddy
    I agree with using laquer thinner to wipe it down. Just dont soak it and let it dry really well. If you use it too heavy the edges of your filler will try to lift some...good luck!
  11. hot74roadrunner
    hot74roadrunner
    you have to use acetone on slicksand it is a fibergl*** primer and if you dont block it out with 80 grit on a 16 inch sanding block or a orbital air file or after you paint it it will look like a kindergardener did bondo work on your car were there is no bondo you can take laqure thinner mix with bondo till it is like a thin a gravy add more thinner if disired and 1 part laquer primer and then hardener and you have the same ****
  12. Spanish Fly
    Spanish Fly
    laguer thinner is way to go wipe and sand 1200 to take thinner marks. work verry nice good look.
  13. Redbuddy
    Redbuddy
    from Cordova al
    I put the wrong act. In primer one time it was hard to get off.I got it off paint job was great .you learn from mistakes
  14. Wash the residue off with laquer thinner,wet on a clean towel,let it breath out for a day,sand area with 180 ,or whatever you had finished your bodywork with, and you will be back on track.
