Customs Paint question
Discussion in 'The Hokey Ass Message Board' started by Slick111, Aug 16, 2024.
  1. Slick111
    Slick111
    I need to paint the firewall floor pan and inside trunk area possibly the door jambs doing my self due to cost looking at TCI Global single stage the whole car later not a show car in these areas just need to get this done to ***emble car the exterior will be done by a pro wondering if singe stage acrylic enamel or urethane dont want to hear the body man say you used the wrong paint
  2. Who cares what the body man says
    Solid color or metallic?
    gimpyshotrods likes this.
  3. Go with urethane. Far more chip resistant
    gimpyshotrods and anthony myrick like this.
  4. JimSibley
    JimSibley
    Like anthony said, is it solid or metallic? Solid color then single stage should be fine, metallic paint should always be done in a base coat, clear coat. The reason for this is that you can not fix bad spots, or color sand and buff single stage metallic easily.
    alanp561, hrm2k and anthony myrick like this.
  5. Slick111
    Slick111
    Solid color only. Liking the California orange color on my 54 Studebaker coupe very solid car the floor and firewall still has good original pink paint should I prime-seal this first have pressure washed still has a shine to it.
    anthony myrick likes this.
  6. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Old paint rules….
    JD Miller and anthony myrick like this.
  7. enamel sprays very EZ. Chips easier. Can be used without a hardener.
    Urethane is a little tougher and has a little more gloss.
  8. 05snopro440
    05snopro440
    Sounds like he was concerned about possible compatibility.
  9. HOTRODNORSKIE
    HOTRODNORSKIE
    Sounds like a budget spray enamel is slightly cheaper than urethane sprays about the same all paint chips the same it's all in the prep. If you choose the urethane it's Moore toxic then the enamel so keep that in mind.
  10. For a metallic I’m shooting base/ckear.
    Single stage metallic looks like poo
    Lloyd's paint & glass likes this.
  11. JD Miller
    JD Miller
    Yes Sir !:D
    I used acrylic enamel in the "old" days. Guy in the small shop next to me used Dupont Emeron( urethane). Back then the Emeron wasnt shinny( and actually looked like ****) . Could have been cause Emeron was a new formula . Could have been the painter, maybe he put some secret ingredient in it like a dash of lacquer thinner or some LSD or something.
    Id use the single stage urethane now days, Acrylic enamel shrinks over the years:D
  12. Yep. All paint will chip.
    Oil based and straight enamel do that easier.
    Plus they loose gloss faster than a urethane.
    All paints are unhealthy
  13. gimpyshotrods
    gimpyshotrods
    I routinely piss people off by proving them wrong.
    I have been told over and over again that it is not possible that I have had success with TCP Global paints.
    I use urethane for durability and longevity.
    Just to further push the point, for a long time I had a custom painted Ducati. Everyone loved it, but called me a liar when I revealed that it was TCP Global urethane, sprayed with a Harbor Freight purple gun. I even did all of the primer work with two slightly modified HF purple guns (reamed the tips out to larger sizes).
    My Falcon is about to go into satin pearl, and I will give you three guesses where I got the paint.
