Technical Paint question
Discussion in 'The Hokey Ass Message Board' started by AldeanFan, Apr 9, 2026 at 9:45 AM.
  1. AldeanFan
    AldeanFan
    image.jpg image.jpg My wagon came with a half gallon of leftover paint -pictures are attached.
    I need to spray a few small parts,
    From what I’ve been able to determine from the label and a google search I only need reducer an not a hardener/activator?
    is that correct?
    I’ll be spraying this over 2k primer.
  2. Like, cosmic man.
    AldeanFan likes this.
  3. guthriesmith
    guthriesmith
    That's what I am seeing...just paint and reducer.
  4. guthriesmith
    guthriesmith
    ***uming you are planning on clear over it?
    MMM1693 and chryslerfan55 like this.
  5. AldeanFan
    AldeanFan
    Yes
  6. BJR
    BJR
    Base coat never uses a catalyst that I have ever seen. But you need to clear over it with catalyzed clear.
  7. Just reducer in this one.
    There were a few base coats that had a catalyst
    I know guys that add a cap full of clear hardener to the base. I’ve done it.
    Reduce and spray
    SS327, AldeanFan and guthriesmith like this.
  8. guthriesmith
    guthriesmith
    I have also seen at least a couple basecoats that use a catalyst, but it has been several years ago that I used those.
    MMM1693 and AldeanFan like this.
  9. JimSibley
    JimSibley
    Most higher end base coats have a catalyst, but it is usually optional. I use 2 separate systems at my body shop, both are catalyst optional, and I prefer to spray them without it. Seems to lay down nicer. Your base is a 2-1 one mix with reducer, you can usually go with a little less reducer, for better coverage. If you are not planning to seal the parts before painting, I would sand them in 600-800 grit depending on if it is a fine metallic color.
  10. AldeanFan
    AldeanFan
    Thanks everyone!
    My experience painting is limited to buying all the materials for a specific project so that everything matches and is guaranteed compatible.
    my research tells me this is a low end paint but it’s what cam with and on the car.
    it’s a solid, non-metallic colour and the parts are an interior panel and an under hood heater block off plate so it doesn’t have to be perfect although I’ll be a picky as possible.
    Here’s the colour:
    Just Gary likes this.
