paint questions- got info please check in
Discussion in 'The Hokey Ass Message Board' started by hiboy32, May 12, 2005.
  1. hiboy32
    hiboy32
    from Omaha, NE
    I have a few questions: first what primer is actually black? The last time I bought black primer to run for a short time , was actually dark grey. I really want back, this is to cover up the body work on a chop on a black car. Paint will come later this summer.
    second, is blitz black a satin or flat black? and can it withstand the elements?
    any help would be apreciated.
    thanks, jeff
  2. 56droppedhardtop
    56droppedhardtop
    dp90. its a sealer. its black. and its a ***** to sand.
  3. Radshit
    Radshit
    I bought some etching primer the other day...it was black......looks real nice when layed down and tough too.....I think it was made by NASON.......
  4. Brandy
    Brandy
    from Texas
    That's what I sprayed. NICE stuff!
    **x
    Brandy
  5. Slag Kustom
    Slag Kustom
    sikenns has a great primer called colur build it is a high fill and easy to sand but very costly. you can make any color you want with it. the black is really black but when it is sanded it becomes more of a dark dark grey.
  6. hiboy32
    hiboy32
    from Omaha, NE
    Is Nason a PPG product? And is an etching primer good for high build applications. There is a little body filler in the area to be primed. I guess that it doesnt matter if the primer is a high build. Just looking for a 'cover up' primer. This car has to be cruised and we wanted it to be dressed in its best black.
    Sikkens sounds great till you get to the cost. I dont have any Sikkens products, so I would have to buy it all - reducers and hardners.
    I really appreciate the help. I like real world guidence . Sometimes the sales reps just say what you want here.
  7. overspray
    overspray
    I've got the sikkens on my "A". You get what you pay for. The sikkens will go farther in the "fill/build" than most others. If you need it for a cover-up type primer that you can sand and reprime later, you can use the color build black and the sealer hardner (there are 2 hardners for color build primer-sealer/primer) and add reducer. This will give you a satin/flat black tone that you can scuff and put fill primer on later. If you mix it 1 part primer to 1/2 part (sealer) hardner to 1/2 (or a little more) reducer, then 1 quart of primer will give you 2 quarts or a little more of sprayable product. This can also be put wet-on-wet over most good etch primers. Put on at least 2 or 3 coats for some protection from the elements. 2 coats of this in the sealer form would be comparable to between 4-6 coats of DP90 in film thickness. I'm guessing that 4-6 coats of DP90 will cost pretty close to what 2-3 coats of the sikkens in sealer mode will run. Don't use DP90 over an etch primer-they are not chemically compatible.
    overspray
  8. ham-boned-ford
    ham-boned-ford
    Nason, is a low end brand of Dupont so any Dupont jobber should have it. Etching primer is made to be applied at .5 to .75 mil thickness and will not do any filling at all. Primer fillers are generally in the 2-5 mil range.
  9. hiboy32
    hiboy32
    from Omaha, NE
    thanks for the help ,sounds like I may need to decide how much to spend.
  10. buickbabe
    buickbabe
    Sounds like that first part was well covered, but here's my two cents. If your trying to save money I would just use blitz black, it's cheap and so far I haven't seen any problem shooting other paint over it after sanding, bodywork, and priming, maybe someone else has input on this? It looks satin to me and alot nicer than any flat black I've seen, sure looks alot better than DP and seems to hold up better. But a PPG guy told me that you can put filler and paint right over the DP without sanding it even if it's set for months, I've never tried it and I don't know if it's true.
  11. Scott
    Scott
    Ihave a qt of DP90Lf if you need it 20.00 I paid 40.00
  12. hiboy32
    hiboy32
    from Omaha, NE
    Scott, I appreciate the offer , but I will decline. I think we will see primer this weekend.
    Can anyone help me on the blitz black, what is it? I went to TSC and they have an implement enamel, it is called 'low gloss black'. Is that what I am looking for?
  13. Tha Driver
    Tha Driver
    from S.E. USA
    Get it down to bare metal & use the DP90 that someone suggested (it's Dittzler/PPG's epoxy). then full it with a good brand name bondo - it sticks better to the epoxy than to bare metal (feathers better too). Then prime it again with the DP. Later when you get back to work on it sand it & use a high-build on it wherever you need to do blocking. seal it wit epoxy again before shooting paint. The epoxy is a little expensive but it's money well spent!
    The epoxy is not that hard to watersand after it's dried a week or two. You can prime/paint over it within a week without sanding.
    FYI I've been building custom cars for 30+ years...
    BTW any satin or especially flat paint will not hold up to the elements as well as gloss will.
    ~ Paul
    aka "Tha Driver"
    Giggle Cream - it makes dessert *funny*!
  14. boothguy
    boothguy
    Sikkens has a cheap(er) line called Lesanol. I think the big difference is in the warranty and tech support- important to body shops but probably not to the home builder. There are some high fill, sandable, self etching primers out there, kind of a one step product but the ones I've used were green or yellow. Maaco's shoot a lot of Nason, for what thats worth. I know you can't get it off the booth
    fan without a grinder or sandblaster.
  15. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Etching Primer should only be used on top of bare metal.
    Its a first step primer.
    then you would spray DP90 over that
    Is this something thats going to be painted some day or are you just throwing on a coat of FLAT BLACK?
    Tuck
  16. 40StudeDude
    40StudeDude
    Don't forget, most primers are not waterproof...your bare body will rust under the primer if it gets rained on a lot or if you wash it a lot or if it sits outside a lot (it's called condensation). You'd be better off with a brand that is waterprooof...not water resistant.
    If you run DP90, it's going to chalk up on you after a few months and turn a ****ty gray, then you're going to have to do it again...providing you want that look...and it requires sanding before you shoot it again.
    R-
  17. hiboy32
    hiboy32
    from Omaha, NE
    Hey tuck this is going to get painted soon, it just needs to look presentable in about two weeks. The car is black originally and we just need to cover up the chopped top.
  18. overspray
    overspray
    Blitz Black is an alkyd based synthetic enamel. It could be sensitive to the strong solvents used in urethanes, acrylic enamels and lacquers which can make it wrinkle or lift should you put these products on top. Try to plan your system if you are going to continue the work later to avoid having to sand it all off to start over.
    In an effort to save my typing "finger", check on my Tech post "Bondo 101" for some info on primers and body fillers.
    Good luck.
    overspray
  19. Tha Driver
    Tha Driver
    from S.E. USA
    For this reason I think the epoxy is the way to go. It will hold up (protect the metal) better than most (all other?) primers in the weather, & you can water sand it & put anything you want over it when the time comes to finish the work. BTW no need for an etching primer if shooting epoxy over clean dry metal.
    ~ Paul
    aka "Tha Driver"
