Technical paint
Discussion in 'The Hokey Ass Message Board' started by butch70462, Aug 7, 2016.
  1. butch70462
    butch70462
    am painting some aluminum panels going to use a laquer primer will this work, will it stick to aluminum
    TKS Butch
  2. David Totten
    David Totten
    usually not recommended unless you spray zinc chromate first. Most of the newer primers are Ok on aluminum.
  3. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Epoxy is the way to go on Aluminum.
    VR&C.
  4. oneratfink57
    oneratfink57
    from Wisconsin
  5. nmpontiac
    nmpontiac
    from Taos, NM
    Aircraft Spruce has quite a few aluminum primers - works on planes, fine for cars.
  6. philly the greek
    philly the greek
    from so . cal.
    I've had good results the last 10 years using Valspar Direct to Metal two part primer . Covers well with great adhesion , sands nice and doesn't shrink back after time . As a plus you can get it tinted to match what ever topcoat color that you're using .
  7. Paint Guru
    Paint Guru
    from Bowdon, GA
    Lacquer primer will not work. Please provide information about the aluminum. Is it anodized? Do you plan on sanding or just degreasing and topcoating? Do you want the aluminum in a primer? Or a actual topcoat? These questions need to be asked before ANY recommendations are given.
    Aluminum is a easier metal for paint to stick to because it's softer, however it can corrode very quick. Lacquer primer doesn't bring anything really to the table, it will only provide a mechanical adhesion (by sanding).
    Sent from my SM-N920V using The H.A.M.B. mobile app
  8. butch70462
    butch70462
    tks Guys went with two part epoxy painted and let dry over night could not s**** off with a razor
