Painted cab on frame
Discussion in 'The Hokey Ass Message Board' started by RustyBolts, Nov 9, 2006.
  1. My home-made candy tangerine paint-job on the cab after I bolted it back on the frame. I painted the firewall Porsche "Biarritz White" which is a slightly creamy white color I found in the book at the paint store.
    I chopped it 4-1/2" and channeled it 6". I reshaped the lower corner of the cowl to clear the rear mount for the front wishbone. I Z'd the rear and notched the front. I've been working on this heap for 3 years. I had the body on and off the frame about five times already, and hopefully it's bolted on there for good now. It started out as just a beat up rusty '32 Ford Model B cab with about a 100 bullet holes and pick axe holes in it. I spent about a whole year doing metalwork on the cab to patch it up and straighten it out.
    Waddaya think? :eek: :D :eek: :D
  2. s.r.i.
    s.r.i.
    from Hell
    Looking good.
  3. LowFat48
    LowFat48
    NICE , love the color combo
  4. crazy34fordtk
    crazy34fordtk
    looks great!! did you have to buld the doors? i have a real bad drivers door on my 34. im new to this are they hard to find?
    Again your truck looks great!!
  5. stovbolt
    stovbolt
    lookin good !!
  6. Bloody beautiful
  7. screwtheman
    screwtheman
    Looks good from what I can see. We need some closer/bigger pics! Did you paint it in your garage? Did you tint your clear or use HoK Kandy or ? Inquiring minds need to know. :D
  8. F**king beautiful, any more pics..of mock up stage etc so we can see the whole idea...?
    Lokks awesome so far!
    Cheers
    MAIKI
  9. Paint on a hotrod!:eek: What's this world coming to.
    I think it looks great, the color will make it standout, add alot of chrome and or polished aluminum to the engine and you will have a real stunner there. Great job so far.
  10. Thanks for all the nice comments!
    To answer your questions:
    The doors were a real mess. The lower hinges were torn completely out of the doors. The bottoms of the doors were rusted through, and the door skins were mangled and torn up. I cut away the lower part of the door skins and reworked the front side of the door and added bracing to hold the lower hinge in a better way than the weak way the factory had designed it. Then I cut away the bottoms of the doors and welded in new door bottom patch panels. I bought the patch panels from a place that sells reproduction Alfa Romeo parts and they also sell a few '32 pickup parts. The door bottom patch panels weren't quite right though because they bent one part of it in the wrong place so I had to slit them lengthwise and weld them back together until they were the same as the old ones. Once I had the door bottoms fixed, I cut away the door skin up to about 1" below the beltline, and then installed new door skins from that same Alfa Romeo place. I butt-welded the door patch at the top and folded the lip back around the door framework the old fashioned way using a hammer and dolly. I later installed bear claw latches. I mounted them down kind of low in the area where the dovetails were so that I'd be able to install glass windows if I want. I might just leave the side windows out though because that's how I'll be driving it all the time anyway.
    I did the paint in my driveway. I strung up tarps to block the wind. It's House of Kolors tangerine candy over a top secret mix of basecoats that I put on first. It's the first time I ever painted a candy job. It took a whole day from early in the morning to just before the sun went down. The hardest part was dealing with the little bugs that landed in it. When I was done there were lots of little "zits" on it from tiny gnats that had landed in the paint. I wet-sanded the clear down with 800 grit and then shot two more coats of clear on it on a cool morning when the bugs weren't flying and it came out like glass. Except for a few runs in the clear that I have to sand out and polish, I was pretty happy with it.
    Yeah, I could have just primered it. But I always wanted to try doing a candy paintjob. I like hot rods AND customs, so I'm trying to sort of roll the two styles together into one, making a hot rod with a custom sort of style. I'm going to be putting steelies with wide white bias ply tires on it. I'm making it on a pretty low budget. So far the biggest expense was the paint. Those HOK paints really add up. I'm going to be using a 327 Chevy for power with an old Offenhauser tri-power intake. I wish now that I had picked a more interesting engine though. I almost went with an Olds 425 from a junkyard Toronado, but changed my mind at the last minute.
    Thanks again! :D
  11. Hackerbilt
    Hackerbilt
    Kandy in your driveway?
    I LOVE it! ;)
    Both you AND the truck kick major ass. Keep some updates coming...
  12. Royalshifter
    Royalshifter
    Moderator
    Very nice and keep us updated.
  13. A "before" pic. This is what it looked like when I dragged the cab home from a swap meet four years ago. It sat around for a year while I gathered up parts for it and thought about what I wanted to do with it.
    :eek: :eek: :eek: :eek:
  14. haring
    haring
    Looks good from 100 feet.
    Show us some bigger photos!
  15. I'm trying to figure out how to fit a bigger picture on here. Is this a little better zoomed in? I don't have an easy way to make the file sizes small enough so that it'll let me put the whole picture on here.:confused:
  16. Evel
    Evel
    1. 60s Show Rods
    Nice job...
  17. CharlieLed
    CharlieLed
    Nice job Bolts....this is what I like, a FNG who doesn't waste his and our time with smack posts; instead, he's doing good work and posted pics of a fine lookin' hot rod. Keep up the good work, we need more like you here!
  18. Chopper Demon
    Chopper Demon
    Looking good man, Are you gonna have done for the Frisco show in Janurary.:D
  19. LoBrow
    LoBrow
    from MI
    That is looking great. What are your plans for a box? Engine? Keep it up!!
  20. Man, that's a sweet color!!
