painters, questions for the pros on how to fix this
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Oct 27, 2011.
  1. Had a bad day today, what would to do?
    Got an OT work van in for some body work, 2 small metal patches, a couple major dents,
    hinge pins & new door, then scuff & shoot the whole van in white single stage enamel over a very solid factory bccc.
    I had 90 % of it done and had the clear coat blocked down to 320 and ready to paint .
    That's all good till this happened.
    The entire van got DA ed with 150. I'm still tryin.g to figure out how but it is what it is at this point. DA Busted thru the clear sparaticaly and down to bare metal in a couple dozen edges , 150 scratches everywhere and that's a lot of surface area..
    This van belongs to a friend of mine and I don't want to give him a turd, nor do I want to do aajor refinish on a work van.
    One buddy said shoot it with a sealer then enamel and be done with it, then he said if you want it right, 2 k filler primer, block and then go from there.
    What do you guys do ?
  2. Bigchuck
    Bigchuck
    from Austin, TX
    I'm not a pro and have no advice,but what do you mean you don't know how it got sanded with 150? It was all ready to paint, the mysteriously got sanded with 150 grit? WTF
  3. niceguyede
    niceguyede
    from dallas
    Enamel will cover some bad *** scratches. For a work van I would do what your buddy said.....seal it and shoot it
  4. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Pics please,Without seeing it ,Id Probablly seal and reprime ,And 400 sand and reshoot,,,,I just dont understand da ing anything that is ready for paint ,I block wet,,,,,,,,,,,,,,,,
  5. I didn't do it, I wasn't there, my helper thought he was helping - mis communication, mis understanding, don't mater at this point. I blew a gasket and need to fix this problem and the hole in the roof when I went thru it. Lol
    Like I said it is what it is now.
  6. poopeye
    poopeye
    Shoot a coat of primer, sand it with 320, seal it and...........paint.
  7. scottb356
    scottb356
    it's going to look like **** unless you give it 2-3 coats of primer and re-sand/ da with 320-400, then shoot the color
  8. niceguyede
    niceguyede
    from dallas
    It's a white work van....put a couple of extra coats of enamel on it. When it shrinks after a couple of weeks buff it out a little. It's a white work van!
  9. BOP-Nut
    BOP-Nut
    I'd DA the whole thing with 150 some more, then 220, 2k prime it... block it out and re shoot it.
    Even if it's a work van why do something if you're going to do it ****ty ya know? I'd be embarr***ed if any one saw the van after all of those sand scratches come back up to the surface.
  10. Yea No ****.
    Id like to keep my friend and not spend 4 extra days on it.
  11. poopeye
    poopeye
    Why block it. It's a WORK van right?
  12. pimpin paint
    pimpin paint
    from so cal
  13. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Just take the time and do it right ,I know you will.You could reprime with featherfill block and reprime and then shoot it with enamel.Probably the least expensive on your end,,,,,
  14. overspray
    overspray
    Depending on the paint brand you prefer, there are hi build sealers available that will have film builds around 1.5-2.0 mils per coat and have a non sanding recoat window around 72 hours. If you are using enamel (acrylic or urethane) you should get 1.5 mils per coat. Find a compatible hi build sealer, spray 2 coats and let it sit for a day (overnight), nib sand, tack it and spray 2-3 coats of color. That should give you 7-9 mils of film build which should take care of the 150 grit scratch. Even if you have some shrinkage later it should be minimal. If you have a bake booth, flash bake the sealer, let it cool, check for sand scratches and maybe lightly sand any bad spots, then spray color. White pigments are usually hi solids, too, which should help. Film build and plenty of flash time between sealer and color. That will help the sealer do a better job.
    You may have to look for compatible hi-build sealers in fleet or industrial products. If you have a good sharp paint rep he can find what you need. I have used some products from PPG or Sherwin Williams that fit the bill.
    overspray
  15. I though I was ****ed, no money now for sure.
    Hopefully I can keep the out of pocket down to a minimum.
  16. matthew mcglothin
    matthew mcglothin
    good point.
  17. Read this to my girl and she laughed just a little bit to hard.
    She's in the shower now
  18. He wants it straight . Them sides are huge
  19. RUBBERNECKKIN
    RUBBERNECKKIN
    from MICHIGAN
    You could just quick DA it with 320 to "smooth" out the 150 scratches, then you can spot prime bare spots and edges. I would then smooth out the primed areas with 320, then seal and shoot it and you will be good!!!
    Yep, that's what I would do. Nice and easy.
  20. autobodyed
    autobodyed
    from shelton ct
    if the 150 wasn't DAed on a 45 degree angle, just re-DA it with 320, nice even wet coat of sealer, and put 3 coats of color on it and call it a day.
  21. glassguy
    glassguy
    rubberneckkin hit the nail on the head!!!!! everyones saying to block it??? i realise although its a work van, that you want it to look good.. so on those giant slab sides just make sure you hold the d\a flat!!! im sure it will be just fine
  22. lippy
    lippy
    from Ks
    Your buddy was right.(At that time) Lippy
  23. Schmidy
    Schmidy
    from Minnesota
    I have painted for 10 years and this is exactly what I would do. DA it with 320, Use PPG DP 40 as a sealer, maybe do two coats, let flash for a good while, then 3 coats of color. Get the helper to resand it, couple hours you will be good to go.
  24. apound
    apound
    my thoughts exactly
  25. lippy
    lippy
    from Ks
    Oh, I thought he wanted a minimum of exspense. My bad. Lippy
  26. metalman
    metalman
    I agree. I wouldn't bother priming the van, I'd just resand with 320 or so , shoot a coat of good sealer (something that would go over the small bare metal areas ok) and paint it. Enamal is a LOT more forgiving then bb/cc are. We use to final sand with 220 dry all the time back in the enamal/ lacquer days.
    Personally I'd use DP-40 as a sealer, not only because it adhears to bare metal so well but it might help any swelling on the edges where the clear broke thru and DP fills sanding scratches well.
  27. lorodz
    lorodz
    i do this for a living 320 on the d,a than wet sand with a grey scuff pad, and scuff stuff (yes thats the name ) anything showing metal, hit it with some high build primer and some guide coat than re sand with a soft block and some 500 till nice and smooth than seal it,let it dry than 3 base coats of color nip it if you want (not ness) than 3 coats of clear ...unless single stage than just seal and blast your 3 coats of color ..let it flash 15 mins in between coats ..good luck
  28. derbydad276
    derbydad276
    its a work van grab a roller lol
    320 is the way to go wet caot of sealer and grab the color
  29. JimSibley
    JimSibley
    This is the right answer. i have had to fix the same mistake on a work van and believe it or not I was even spraying it in white as well. it worked just fine. look at the bright side, the paint will really stick well.
  30. newsomtravis
    newsomtravis
    from pville, ca
    just have your helper change to 320 paper and keep on sanding, seal it all up and shoot it.....
