Painting a frame with light surface rust.
Discussion in 'The Hokey Ass Message Board' started by Brog, Feb 25, 2013.
  1. olscrounger
    olscrounger
    POR 15 seems to work well and flows out nicely--don't get it on you-it takes a while to get off! Kid got a 40 with a frame done in POR15. Wanted to redo and paint it. He used enough sand when blasting it off to make a beach !!! Tough stuff .
  2. That's exactly what we like to do. They make a weld threw self etch that we use that you can just about Tig over if you must.
  3. Rocky
    Rocky
    Classified Editor
    I don't know if it's wrong or right but I first had my 34 frame sand blasted and before it had time to flash-rust I trucked it home and blew a coat of acid etch primer on it. It's easy to grind off before welding and easy to use rattle-can acid etch primer over the repaired/welded areas...works for me.
