Hot Rods Painting a radiator
Discussion in 'The Hokey Ass Message Board' started by drew1987, Aug 5, 2016.
  1. drew1987
    drew1987
    Howdy all,
    Something in my gut is telling me not do paint my new aluminum radiator black with rostoleum grill paint. That it it could inhibit it's effectiveness. Is my gut correct?
    Thanks
    Member:
    Rochester Street Rods - Est. 1970
    http://www.rochesterstreetrods.org
    CrossMembers Car Club - Hebrews 12:2
    http://www.crossmemberscc.com
  2. Montana1
    Montana1
    I always thought they were painted black, like a wood stove, to radiate the heat better...
  3. Blues4U
    Blues4U
    from So Cal
    Mont**** is correct and your gut feeling is wrong. Darker surfaces radiate heat better; a radiator painted black will shed heat faster than a shiny aluminum one. Not that it will make much of a difference, but painting it black will not harm the heat transfer properties, it will enhance it.
    Besides, a black radiator looks far better in a hot rod than an aluminum one. I painted mine recently when I had it out for a repair, I like it far better black. Something just wrong with an aluminum radiator in a hot rod, IMO of course...
    lothiandon1940 and Montana1 like this.
  4. drew1987
    drew1987
  5. Montana1
    Montana1
    I gotta fess up... mine is aluminum and I never got it painted! Don't whip me! :eek::eek::eek:
  6. Texas Webb
    Texas Webb
    Just enough spray to coat it,don't go too thick.
  7. drew1987
    drew1987
    This radiator was a birthday gift. It's identical to stock other than being three cores, a modern (70's) cap, and no metal tube to dump expansion on the floor. It has a ****** cooler, too. It was a gift
    From someone who knew I wouldn't spend the money on my self. Very nice unit. Painted black (lightly) it will disappear into my engine bay like every other 66 year old part
    Member:
    lothiandon1940 likes this.
  8. squirrel
    Making it disappear...I like how you think....
  9. drew1987
    drew1987
  10. Texas Webb
    Texas Webb
    Be-ing its a gift probably from a well meaning person-paint it and run it.
  11. Flathead Dave
    Flathead Dave
    from So. Cal.
    Paint it. It won't hurt it.
  12. Etch prime first?
  13. Hope your Grille paint isn't too shiny, shiny black paint doesn't radiate heat as well as flat or satin finish. JW
  14. Had my avatar aluminum radiator powder coated satin black ($40.oo) , looks great and looks like it cost $900
    Blues4U likes this.
  15. jimmy six
    jimmy six
    If it was made with an oval top it would look better but aluminum or br***/copper satin to barbecue black always looks best to me.
  16. Rusty O'Toole
    Rusty O'Toole
    Barbecue paint is great for this, tough and heat proof. A couple of thin coats and let it go at that. Too thick and it acts as insulation, but black paint helps the heat to disperse.
  17. Hnstray
    Hnstray
    from Quincy, IL
    Not one post here claiming a black radiator dissipates heat 'better' cited the physics that support that contention. It MAY be true....I don't know......but is this a 'belief' or a 'fact'? I am not questioning whether it 'looks' better or not, only how does that make a difference in how it works.
    For many decades vehicle manufacturers painted radiators black, but so were generators, starter motors, distributors and air filters.
    I believe it's true that dark colored surfaces absorb heat from an external source at a greater rate than light colors, such as from sunlight, but it's not immediately obvious to me what that has to do with dissipating internal heat. Since a radiator is a liquid to air heat exchanger, and the air flow contact with the fins absorbs the heat, exactly how does color affect that process?
    Ray
    Cosmo49, Racer29, Jet96 and 5 others like this.
  18. All colors have a frequency, ranging from gloss white to flat black. That's how. Try painting two cans of the same size, one gloss white and the other matt black and fill both with boiling water and see which one cools faster. JW
  19. clunker
    clunker
    from Boston MA
    Its true, it's explained by Kirchoff's law of thermal radiation:
    "For an arbitrary body emitting and absorbing thermal radiation in thermodynamic equilibrium, the emissivity is equal to the absorptivity."
    Check this out, some car guys and a scientist test the hypothesis:
    Cosmo49 likes this.
  20. drew1987
    drew1987
    This is great info guys thanks.
    This radiator the shop press where amazing gifts because I never would have spent the cash, but there they were on my birthday. I felt like a little kid again
    Member:
    Rochester Street Rods - Est. 1970 http://www.rochesterstreetrods.org
    CrossMembers Car Club - Hebrews 12:2 http://www.crossmemberscc.com
    clunker likes this.
  21. drew1987
    drew1987
    Also I've ***umed all along the tank could be painted any color I want but the fins are the real concern. Sounds like if I don't go to thick (of course) that I can paint them too.
    Does anyone know a semi-gloss? My grill paint is either flat black or gloss black. I'll add I've used the flat back with a shellac clear and it looks totally vintage but of course that won't work on this. The flat is like a chalk board so that would not work and the shiny is too shiny
    Member:
  22. c-10 simplex
    c-10 simplex
    i think Smokey commented about painting stuff black, but i can't find it and don't have time to right now.
  23. Buy a can of radiator paint at the auto parts store and hose it down. Don't get it on to thick.
    Forget about all the theories and **** radiators have been being painted since gawd knows when.
    firstinsteele likes this.
  24. squirrel
    Bare aluminum radiators in old cars look really out of place...any black paint on it will make it look so much better. and my guess is you'd be hard pressed to measure a difference in performance, one way or another. But yeah, black is less reflective than bare metal, so it transfers more heat.
    '51 Norm likes this.
  25. Jim,
    You will appreciate this if no one else does. I walked into the shop of an older friend when I was a kid and he was spray bombing an aluminum intake. I thought it was odd and took a closer look. There lay an offy 2x4 that looked like it had been adjusted with a ball peen more then once. I asked what was up and the old fella just said this, "if you aint proud of it paint it."
    I suppose that applies to aluminum radiators, don't it. ;)
    '51 Norm and squirrel like this.
  26. dodge35
    dodge35
    from kentucky
    Eastwood sells radiator paint in gloss and satin black. $13.00 12oz can. Never used it so I don't know if it's any good. Seems kind of pricy to me.
  27. G-son
    G-son
    from Sweden
    Unless you dip the radiator in the paint, you won't get paint deeper into the core than maybe 1/4". Most of the core remains unaffected.
    Nicholas Coe likes this.
  28. That depends on your technic and how close you have the spray devise from the radiator core, 1/4 inch, you must be standing across the room. JW
  29. drew1987
    drew1987
  30. drew1987
    drew1987
