Painting Headers what to use?
Discussion in 'The Hokey Ass Message Board' started by fiat gasser, Jan 7, 2009.
  1. fiat gasser
    fiat gasser
    I am wondering what is on the market for high temp header paint? Is there a product that is activated with the exhaust heat and is more durable than rattle can paint?
  2. jpaull
    jpaull
    VHT's "Flame Proof" paint is one of the only 1500 degree paints. Its the only one I have come accross that doesnt burn off. Just prep as well as possible with cleaner and paint in a warm area, and then yes, you can fire it up to cure after initially dry. Kragesns does sell this in there high performance section, and also at this link:
    http://www.jegs.com/p/VHT/749303/10002/-1
  3. RAG66
    RAG66
    from WASHINGTON
    POR 15 manifold grey or black will not burn off manifolds but don't know about headers? Would'nt be afraid to try it, it's good stuff several real life applications here even brake drums. No disappointments:)
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    used VHT before..so far so good
    I have a wood burner in my shop.
    I cleaned my headers with acetone.
    than 1 light coat..set them on the hot wood stove for an hour, than another light coat and let it sit for an hour than the last coat and let it sit on the stove for an hour , than I painted the inside of the header tubes too..again while letting it cure on the wood stove..
    4 years so far...so good
  5. Jimv
    Jimv
    I've used the POR15 bright silver with great results, i swear by the stuff 7 thats after trying everything else!
    JimV
  6. Graham08
    Graham08
    I have used VHT on racecar headers with good success. The key is to sandblast the pipes first, and only apply enough to get complete coverage. When I put it on too thick, it just peeled off.
