painting headers
Discussion in 'The Hokey Ass Message Board' started by evobuilder, Mar 7, 2014.
  1. evobuilder
    evobuilder
    I have a brand new set of lake headers (thanks Gear Drive) and need to get some paint on the for mock up and shake down on my 27 coupe. So.... I have a couple of new cans of VHT 'very high heat" header paint and am looking for any tips on getting this shit to stick.... any tips? Obviosuly, cleaning the pipes before painting, but looking for other tips from the HAMB. It doesn't have to last forever..... just long enough to get me through the next couple months before going to Jet Hot Coat.
    Let me know and thanks as always!
  2. pinkynoegg
    pinkynoegg
    read the directions on the can and FOLLOW THEM EXACTLY. I usually get over a year on my coats when done this way unless I get caught in a rain storm or something like that
  3. tfeverfred
    tfeverfred
    I used that on mine and my experience yielded the following: READ AND FOLLOW THE DIRECTIONS TO THE LETTER. Mine lasted over a year and I plan on redoing them this Spring.
  4. 1971BB427
    1971BB427
    from Oregon
    Ditto, and do not heat them too hot when freshly painted! 4-5 starts to warm them well, then shut off between and let them cool completely. I get years between repaints on mine.
  5. HellsHotRods
    HellsHotRods
    I cleaned mine to bare metal and then used RUSTOLEUM BBQ High Heat paint. Been 3 years now and still same color.
    kiwijeff and chessterd5 like this.
  6. choppedtudor
    choppedtudor
    I used VHT and stuck an industrial heat gun in the end to heat um up in between coats...3-4 light coats and they hold up great.
  7. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    I've always used weld through primer first, then high temp paint over it.
  8. evobuilder
    evobuilder
    I think I mastered the header paint job.... will post pics once I mount and burn them in (probably tomorrow).
  9. Devin
    Devin
    from Napa, CA
  10. D-Russ, Those headers look beautiful. Great advice, especially the part about buffing the VHT w/ cotton rag.
  11. vega1
    vega1
    On my Harley's I use stove black on the inside pour it in roll around let dry keeps chrome pipes from turning blue for along time
    jimmy six likes this.
  12. 1971BB427
    1971BB427
    from Oregon
    That's a very good point I forgot to mention! I always buff them with a rag once they're seasoned, and it helps keep the finish nice for a long time!
  13. nutter_street_rodder
    from Nevis MN
    I used to work at a header shop in the 60's. He would heat the tubes with gas torch and paint them with VHT immeaditely. Silver was the choice for magazine ad pictures.
  14. It is all in the baking, we cooked/ heat cycled some in an oven and they stayed nice for multiple years until the truck went away.
  15. I have a set of Gear Drive Lake Headers that were chrome dipped and turned brown. Just wondering if anyone has had any luck using high heat paint on this style ???
  16. BigPerm365
    BigPerm365
    If you have a friend @ a pizza joint, the ovens work great... (after hours of course).
  17. bchctybob
    bchctybob
    The method I've been using for years that seems to work well; (I only use black or white)
    1. Clean the headers with brake cleaner or blast them if they are rusty.
    2. scotch brite (maroon) everywhere.
    3. wash again with brake cleaner - dry for 15-30 minutes. (Prep-sol or equiv also works)
    4. spray 3 or 4 even coats of VHT or Duplicolor header paint.
    5. after the paint flashes for 5-10 minutes - use a torch to heat the headers from the inside until they just start to smoke. Don't linger too long in any one spot, heat the headers evenly.
    6. After they cool, wipe them with a clean rag to burnish the finish. They look like they've been powder coated. They will cure even more as you drive. Wipe 'em off if they get wet or rained on.
    I've had them last 4-5 years on a car that gets driven regularly, they will rust if the car just sits for months at a time in a humid atmosphere.
  18. I seriously hope you are joking.
    tfeverfred likes this.
  19. Blue One
    Blue One
    from Alberta
    Just for your information, my son and I have had several sets of headers ceramic coated. The coater will always charge more to do a set that have been used, prepping takes a lot more work than coating a new set.
    I'm finishing my RPU, it's never been run but the lakes headers I built along with the whole exhaust system will be ceramic coated.
