painting leaf springs?
Discussion in 'The Hokey Ass Message Board' started by westcoaster, Jul 25, 2008.
  1. westcoaster
    westcoaster
    from SoCal
    i got my rear end out, all cleaned up and painted purdy. now the leafs look like ****. i figured i'd repack and use new bushings but can i paint them or will the paint just crack when the springs flex? any tips, what kind of paint?
  2. Dreddybear
    Dreddybear
    I believe Ch***is Black will work just dandy. Mine are painted that way and havent cracked, hell I reversed the spring and it didnt crack...
  3. Crusty Nut
    Crusty Nut
    Yep, I just came inside from painting one ch***is black. I love that stuff. It makes me look like I know how to paint. Ha ha
  4. KJSR
    KJSR
    from Utah
    I have powder coated, KBS coated, spray painted and automotive painted leafs before and have never had an issue. I don't think there is enough flex in the leafs to really matter. Make sure the prep is good or else it will come off pretty quick.
  5. Crazydaddyo
    Crazydaddyo
    I've just wire brushed mine and shot them with Rustolium and I've never had a problem with cracking or pealing.
  6. KKustoms
    KKustoms
    Rustolium here to, looks great no cracking.
  7. westcoaster
    westcoaster
    from SoCal
    you guys use a flat or something like an appliance epoxy rustoleum?
  8. Flop
    Flop
    i painted mine with brush on rustoleum satin no troubles.
  9. whid
    whid
    rustoleum gloss,brush on.works like a champ.............dave
  10. PASTDUEBILL
    PASTDUEBILL
    I live down a dirt road. Satin rustoleum. Brushed and sprayed. Have coat hanger wires all over the shop with parts hanging. Put axle grease between the leaves.
  11. studenut48
    studenut48
    from Hanson, Ky
    mine on the stude was painted chrome yellow and been out in the weather for atleast 15 years and no cracks, some surface rust but not much. I see no cracks on mine.
  12. westcoaster
    westcoaster
    from SoCal
    alright, i guess that about answers my question. thanks for the replies.
  13. Crazydaddyo
    Crazydaddyo
    I've used Satin and Semi-gloss brush on thinned with mineral spirits and shot from my primer gun. A lot better then using thier rattle cans. Job goes much faster.
  14. How do you get the paint to stick to the grease?
    (Just kidding!)
  15. jalopy43
    jalopy43
    I use a good brush on rustoleum gloss black,mixed with clean 30wt. motor oil. It surface hardens, but stays 'gummy" on the inside..I call it my self -lubricating'spring paint'...
  16. 35PontiacCoupe
    35PontiacCoupe
    from COS
    Rustoleum here too- that stuff will stick to anything!
  17. dzahm
    dzahm
    from NC
    I powder coated mine- black of course. They look nice but have yet to see the road. I was planning on teflon tape (3/4 wide) between the springs- anyone try this? I thought axle grease might be a little messy.
  18. Crazydaddyo
    Crazydaddyo
    I've used the Teflon liner stuf from Speedway motors. Then w****d the spring with header wrap to cover tha Non-period look of the liner lip.
    http://www.speedwaymotors.com/p/2079,323_Spring-Liners-with-Lip.html
    It works *****'in, I'll probably do it to all my cars now.
  19. Unkl Ian
    Unkl Ian
    Most paint and Powder Coat will flex, up to a point.
    That's why it doesn't crack on springs.
  20. If you have a friend in the marine industry have him get you some "Awlgrip" paint. It's used on aircraft also........has lots of flex and looks great. I have used it on springs........nice stuff.
