Painting magnesium valve covers
Discussion in 'Off Topic Hot Rods & Customs' started by johnfin, Mar 18, 2025.
  1. johnfin
    johnfin
    from Florida
    I have some old magnesium valve covers i would like to paint silver. I need it to be durable and heat resistant but dont want to spend hundreds on the project, its not a trailer queen. Have any of you guys painted magnesium?
  2. 325w
    325w
    Had a set oGM alum/magn mix powder coated
  3. SPEC
    SPEC
    Do not Powder Coat them they will outgas when heated and they will look horrible!!
  4. Fordors
    Fordors
    This^^^
    I had a set of magnesium covers done in the ‘80’s, had them on my coupe and then later on a GMC. They eventually started to blister and peel, I thought it was a poor coating job, never suspected outg***ing.
  5. 19Eddy30
    19Eddy30
    from VA
    No paint Nor powder coat if it was me I'd would leave natural !
    Or Dow 7 ?
    Deuces, Just Gary, mad mikey and 2 others like this.
  6. arse_sidewards
    arse_sidewards
    from Central MA
    Another vote for "leave natural".
    Makes for a better conversation starter that way.
    Deuces and Eric David Bru like this.
  7. '29 Gizmo
    '29 Gizmo
    from UK
    Get them anodised.
  8. 1952henry
    1952henry
    You could look into DIY Cerakote kits.
  9. earlymopar
    earlymopar
    While you definitely can anodize magnesium, it does work so well on die-cast parts due to a small % of silicone used in the mix in the die casting process. The finish ends up being very uneven and blotchy.
  10. Clydesdale
    Clydesdale
    Sell them to someone who appreciates the mag and buy an alloy set?
  11. 57 Fargo
    57 Fargo
    I would polish them but that doesn’t At all answer the question
  12. Cerakote Air Cure
  13. poco
    poco
    from oklahoma
    • What is cerakote?
  14. johnfin
    johnfin
    from Florida
    What do you thin or reduce Cerakote with to shoot thru a gun?
  15. johnfin
    johnfin
    from Florida
  16. Clydesdale
    Clydesdale
    Cerakote is already very thin, although as with any paint/chemical check out the safety data sheet and instructions before mixing anything.
    In my experience you need an immaculate finish surface before applying Cerakote to get a good result (I guess same with any painted finish.)
    The Cerakote is normally such a thin layer it shows irregularities reeeaaaaal easy.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    what kind of car is it that has mag valve covers?
  18. Cerakote Air Cure can be sprayed right out of the bottle through a paint gun, it dries like paint, and is superior to pretty much any paint or powdercoat. It can withstand glowing red hot exhaust temperatures and is oil resistant. The surface you're coating must be clean and free of any contaminates prior to coating.
    https://www.cerakote.com/shop/cerakote-coating?finishes=cera_c_series
  19. RodStRace
    RodStRace
    To my mind, I'd be concerned with the value of the parts. Mag is rarely a cheap common part (VW cases being the exception). So whatever I put on, I'd want to be able to remove safely too, so I didn't ruin the value. Whatever coating I considered, I'd also check on removing it from magnesium. As mentioned, it requires require safe handling and can react very differently than other materials. If cast it's porous, which means you probably don't want to slather stripper on it either. I wouldn't abrasive blast it either.
    ottersea, mad mikey and Clydesdale like this.
  20. Clydesdale
    Clydesdale
    As an idea of finish here are some manifolds I had Cerakoted for my chevy 216
    Deuces and '28phonebooth like this.
  21. Fordors
    Fordors
    I bought my covers at a swap in late ‘83 or early ‘84, the seller had a stack of raw ones, never painted. I didn’t ask how he acquired them but I thought they were unique and had the PCV holes I wanted. Initially I polished them and the first humid day they pretty much reverted to looking how I got them.
    Not my photo, I found this online. They were introduced on the ‘84 Corvette.
    mad mikey and Moriarity like this.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    EFI is strictly off topic. this is a traditional hot rod forum
  23. Bandit Billy
    Bandit Billy
    Chrome em!
    mad mikey likes this.
  24. arse_sidewards
    arse_sidewards
    from Central MA
    A shop vac would have gone a long way toward preventing that.
  25. johnfin
    johnfin
    from Florida
    I called Cerakote like you guys recommended and while they claim it works on magnesium, ts $40 oz plus shipping. My model badger airbrush hold 4oz. It would cost a fortune to coat a car part.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    what kind of car has mag valve covers???
  27. 38Chevy454
    38Chevy454
    Just some technical info: Dow 7 is just a chromate conversion coating. It has the Hexavalent chromium, which is now considered carcinogenic. That doesn't mean you can't use it. It's the same chromate coating as you might have heard called "Gold Cadmium". The Dow 7 or similar chromate coatings result in a yellow to dull yellow appearance. Note that trivalent chromium is what you commonly find on hardware store zinc plated parts. It is clear or slight blue tint. No mistaking it for the hex chromate, which is yellow or to even near olive drab green color.
    Basically what the conversion coating does is lower the galvanic potential of the surface, as you know magnesium is very active on the galvanic scale (more anodic officially). So by lowering the surface potential, you can delay the onset of the oxidation.
  28. Groovy
    Groovy
    I recently rebuilt a VW engine with a magnesium case. I gl*** beaded the block and painted it with ENDURA urethane enamel. The rough beaded surface is great for adhesion. No primer just silver paint directly.
  29. johnfin
    johnfin
    from Florida
    KB 426 valve covers are magnesium.
    427 sleeper and mad mikey like this.
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    oh man! you have a car with a Keith Black 426 Hemi in it? lets see some pics of the car
    Deuces and Just Gary like this.
