painting master cylinder
Discussion in 'The Hokey Ass Message Board' started by rust runner, Jan 25, 2009.
  1. what type of paint should i use to paint my master cylinder and have it last? thanks
  2. Nobodys Hero
    Nobodys Hero
    from New Jersey
    none.........at least none ive tried
  3. southerncad
    southerncad
    I've used POR-15, both black & clear. The key to keeping paint on it is to get the M/C real clean, I've had good luck using Acetone. Hope this helps.
  4. maw4805
    maw4805
  5. thanks for the info. i'll give it atry. if it doesn't work it will look like the rest of the car
  6. Deuce Daddy Don
    Deuce Daddy Don
  7. 39 Ford
    39 Ford
    I have used "cast blast" in aluminum or cast iron colors its available at your local parts store, made by the same people that make engine enamel.The trick is to clean the mc well and try not to spill brake fluid on it.
