Projects Painting rusty chrome wheels
Discussion in 'The Hokey Ass Message Board' started by Tenacious A, Nov 8, 2015.
  1. Tenacious A
    Tenacious A
    from Willis Tx
    I'm sure many of you have been down this road. Any pointers or tips? [​IMG]
    Sent from my XT1526 using Tapatalk
  2. King ford
    King ford
    from 08302
    Sand blast and etching primer.....
    tb33anda3rd and dana barlow like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    That's what I would do. HRP
    dana barlow likes this.
  4. stimpy
    stimpy
  5. Kiwi 4d
    Kiwi 4d
    Or send to the chromers to get de chromed. Chrome is pretty hard stuff and may be difficult to blast cleanly.
  6. Phillips
    Phillips
    Try an oxalic acid treatment first, those Hollywood wheels are hard to come by and once you blast and paint them not worth much.
  7. Tenacious A
    Tenacious A
    from Willis Tx
    I know what your saying, but they are to far gone. I blasted them yesterday.
  8. pitman
    pitman
    Anyone familiar w/using the acid treatment, on a steel rim w/an alloy center?
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    Tuck is looking for a pair of those wheels. they are hard to come by and worth the effort to restore properly
  10. Jsprengeler
    Jsprengeler
    So what's it cost these days to have rusry chrome wheels rechromed?
  11. stimpy
    stimpy
    in my younger days did it and will tell everyone else don't . ruined a set of Keystone Kustoms as the acid ate the aluminum centers out and left me with a chrome shell for a turtle ... but I was using diluted HCL ( muratic acid ) instead of mag cleaner .
  12. Phillips
    Phillips
    It can be done, but you cannot soak the wheels like you would for a full-steel rim. I've taken oxalic acid (wood bleach) and made a paste with water, using rubber gloves and a soft pot scrubber you can make a huge difference. Oxalic is much milder than HCL but it will still do a number on aluminum.
  13. Phillips
    Phillips
    A bunch - problem is wheels need to be dismantled before plating in most cases, then of course fully polished and then plated, and finally reassembled. There is a wheel restorer in California that will restore the aluminum center/chrome rim wheels, I'll see if I can find the info.
  14. Phillips
    Phillips
    I actually had a full set of 4 with spinners and all a while back that went to Bob B. certainly not perfect but very nice. Hard to come by even a pair, one of those wheels you see one of in a junk yard once in a while but there's usually just one and the center has a big chip out of it!
  15. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I had a chance to buy them and he changed his mind. I'm looking...
  16. Phillips
    Phillips
    Yeah I had seller's remorse as well, was saving for the know-its-never-gonna-happen model A RPU
  17. dorf
    dorf
    from ohio
    blast and powdercoat
  18. PackardV8
    PackardV8
    X2 - I've had a couple of sets of rusty wires sandblasted and powdercoated and they came out great. It's not necessary to remove all the old chrome. The sandblasting gives it enough tooth for the powdercoat to bond.
    jack vines
