1952-59 Ford Painting script, how is it done?
Discussion in 'Off Topic Hot Rods & Customs' started by GAmes, Jul 15, 2023.
  1. GAmes
    GAmes
    The script and the vertical lines were originally black. There was a little paint left but polishing took care of that. Is there an easy way to restore the paint or do I need to hire someone with a steady hand and a tiny paint brush?
    Adriatic Machine likes this.
  2. Paul2748
    Paul2748
    I did by hand - yes a very small brush - get it at a hobby store.
    jimmy six likes this.
  3. jimmy six
    jimmy six
    IMG_2687.jpeg Don’t skimp on the brush. Buy a couple of sizes. I used Testors model car paint with a little thinner. I do my hub caps
  4. GAmes
    GAmes
    My hand isn't that steady. My grand daughter is an artist, but she lives 2000 miles from here.
  5. Alan Freeman
    Alan Freeman
    Mask off everything except a rectangle which contains the word "Skyliner". Get some Rustoleum flat black and spray the exposed rectangle. Let it dry overnight and gently use some four 0000 super fine steel wool to buff off everything but the black in the recessed letters of the word "Skyliner". I did mine 35+ years ago and they still look perfect.
  6. GAmes
    GAmes
    I was thinking along those same lines except I was going to wipe the wet paint off using something flat like a cloth wrapped around a piece of wood. I have the pieces from my parts car Victoria to experiment with. Thanks for the idea.
  7. Adriatic Machine
    Adriatic Machine
    I’ve done the wet paint/ wipe with cloth method and it got a bit messy but after a few tries I got it. Different surfaces will also affect results. If the edges of your feature are not crisp then it has more of a tendency to smear.
  8. Alan Freeman
    Alan Freeman
    You can let the paint dry overnight and then carefully wipe around the edges with a rag damp (not wet) with lacquer thinner instead of using the four 0000 steel wool.
  9. HOTRODPRIMER
    HOTRODPRIMER
    This is exactly how I have done it in the past, I also used this method on my valve covers.
    I sprayed the valve cover and let it sit overnight,
    The next day I used a piece of cloth wrapped around my finger, dipped it in lacquer thinner and gently started rubbing the raised part of the valve cover, after a few minutes and using a clean cloth this is the results. HRP
    JeffB2, orangedog and Dos Cincos like this.
  10. Fairlane 62
    Fairlane 62
    I've used scotch rite instead of steel wool. It tends to leave the edges of the paint sharper since it is flat and stiffer.
  11. GAmes
    GAmes
    I experimented with all the suggestions. Gray scotch brite is too course and dulls the surface. Lacquer thinner was difficult to work with. I used 0000 steel wool to clean up the surface and a pre-paint cleaner. Two days after the paint was applied I used the 0000 steel wool and am satisfied with the results.
  12. tcoupekyle
    tcoupekyle
  13. 50sboy
    50sboy
    Lacquer thinner and Q Tips
    guthriesmith and down-the-road like this.
  14. Zax
    Zax
    Magic Eraser also works well
  15. 56longroof
    56longroof
  16. GAmes
    GAmes
    I wish the rest of the re***embly was that easy to solve. Trying to get the rear windows to roll up correctly is kicking my ****.
  17. TomDobbs
    TomDobbs
    Victoria rear side windows have umpteen adjustment points. Are they manual or electric? If they're like my '55 Merc the windows and regulators are modular ***emblies that bolt to the body. The service manual should have instructions on how to adjust them.
  18. Slicks
    Slicks
    from denison tx
    I adjusted the back windows on my 55 Vicky you just about need the service manual to adjust them it took me about 2 days to get mine adjusted right good luck many adjustment points
  19. GAmes
    GAmes
    They are electric. I'll look at the repair manual again, but didn't see anything. I didn't look in the '53 section.
  20. Alan Freeman
    Alan Freeman
    The 1952 Ford Shop Manual has a detailed section on adjusting the quarter windows on pages 293-294.
  21. GAmes
    GAmes
    I'd forgotten that the '54 manual supplement only covers the things that are special to the '54. I found the correct pages, but it is still a lot of work.
  22. Alan Freeman
    Alan Freeman
    If you think that it is a lot of work on a closed car, I had to get the power windows working and adjusted on my '54 convertible which was twice as hard!
    Kustomline54 likes this.
