Hot Rods painting single stage enamel
Discussion in 'The Hokey Ass Message Board' started by 29moonshine, Feb 15, 2019.
  1. 29moonshine
    29moonshine
    if you clear coat single stage how long should you wait between the last coat of paint and the clear?
  2. bdynpnt
    bdynpnt
    I have done it wet on wet but was using the same family of materials
    Sent from my SM-G965U using The H.A.M.B. mobile app
    dana barlow likes this.
  3. da34guy
    da34guy
    I like 2 wait 4/5 hrs depending on temps, that way ya can sand any small nibs out with 800/100
  4. I have mixed the clear as an integrating clear in the final coat- approx 35% clear/65% colour-all the same paint system
  5. Why do you want to clear it? If it’s just to get a better shine- you can color sand single stage and get excellent results.
  6. oliver westlund
    oliver westlund
    yeah...thats kinda the difference betwen single and 2 stage right?
    Jalopy Joker and jimgoetz like this.
  7. Single stage polished doesn’t have the same ‘plastic’ look to it that clear does- but you can get excellent depth and gloss with single stage- I guess it depends on the look you are after or if you are trying to bury graphics or other custom texture( lace, stripes,etc)
    Allmotor and jimgoetz like this.
  8. 29moonshine
    29moonshine
    it is metallic so I can not sand it has some orange peel and a little trash [ which may buff out] . if I clear it then I can sand and buff
    Asphalt Angel likes this.
  9. K13
    K13
    Read your tech sheets it will have a recoat window. By the sounds of it you have p***ed that window and would need to sand it to get any adhesion. This is why you don't spray single stage metallics.
    0NE BAD 51 MERC likes this.
  10. N2hotrods
    N2hotrods
    Are you using a catylist with your enamel or straight enamel.
  11. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    You would want to sand it any way if imperfections are the reason. Other wise the clear will magnify the problems and no matter how much you sand and buff the clear you will see the orange peal and and other flaws. Many years ago you could color sand and buff metallic's but not any more. Metallic colors should always be base cleared. Larry
    Jalopy Joker likes this.
  12. 29moonshine
    29moonshine
    I agree
  13. 29moonshine
    29moonshine
    I am starting to belive this
  14. s55mercury66
    s55mercury66
    from SW Wyoming
    This 2k sealer had a 24 hr window. My buddy sealed, and went to mix the silver basecoat, and found he didn't have enough aluminum, so he ordered some and it was dropped off 12 hrs later. 4 months later, this started to happen. 20190215_182219.jpg All PPG products, just so you know, and no, I am not bashing them either.
  15. lippy
    lippy
    from Ks
    Why would you put clear over single stage? I think if you wanted clear over you should have went with BC/CC. JMO Lippy
  16. J'st Wandering
    J'st Wandering
    I have cleared a single stage metallic. It is PPG paint and the retailer said that it was not available as a bc/cc.
    Neal
