Painting wheels with tires on them...A lazy way?
Discussion in 'The Hokey Ass Message Board' started by Deyomatic, Aug 28, 2009.
  1. Deyomatic
    Deyomatic
    from CT
    I know the obvious...masking tape and cover the tire, but are there any neat tips for doing this...Something like rubbing something on the rubber parts so the paint won't stick, like WD 40 or something, then washing them with Bleech White, or something like that...or just "Shut your pie-hole, stop being lazy and get out the masking tape."
    I SHOULD have painted them with the old shitty tires on, but the tire guy made me an offer I couldn't refuse to do it today...
  2. 49ratfink
    49ratfink
    Eastwood sells something for this. # 11785 Wheel Shield and Tire Mask Kit .. $24.99
    on page 13 of the late summer 09 catalog.
    local body shop supply place may have them also
  3. Imwalkin
    Imwalkin
    from Tucson, Az
    break the bead away from the wheel, mask, paint.
  4. HemiRambler
    HemiRambler
    We used to use dish soap - no tire machine to break the beads back then.
  5. just rub petroleum jelly on the tires. Then hose off when rims are dry. Just make sure the valve stems don't get too stiff.
  6. ironandsteele
    ironandsteele
    just use note cards. stick them in where the bead is and line the tire with them, overlapping slightly.
  7. yoyodyne
    yoyodyne
    Nope - you'd chip all the new paint changing the tires after the paint was done.
    I like the index card idea, just let the air out, stuff them in and air up again - cool.
  8. LEMMING249
    LEMMING249
    We used to use 3 inch masking tape and actually just place it on the wheel itself making a tube effect but it always left the 1/8 inch on the edge of the wheel that didnt get paint. It never really showed tho. 2cents
  9. OLLIN
    OLLIN
    get a big piece of card board and cut a semi circle in it ( then you can use a rattle can. Thats the lazy way.
  10. Falcon
    Falcon
    from nevada
    Use black paint
  11. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    Paint 'em, then run a laquer thinner soaked rag around the rubber...Rap the rag around your thumb to get tight against the wheel bead
  12. We have a winner!!-MIKE:D:D:D
  13. Like he said, only I run a 1/2" masking tape around first. If you get some overspray on the tire it comes off with lacquer thinner and you don't have to get up close to the fresh paint.
    Someone mentioned the tire machine chipping paint; not with the new machines! They grab the wheel from behind and spin it, the tool never touches the face.
  14. DrJ
    DrJ
    Go to Lowes/Home Depot and get a roll of aluminum roofing flashing.
    It's about a foot wide and you're going to make something that looks a lot like a giant ring compressor out of it.
    Cut a piece about 4-5 times the wheel diameter and wrap it into a belt and fasten it with a bungie cord or two around the wheel to mask off the tire.
    Lay wheels flat on the ground and spray away.
    Use the rest for shims, etc.
  15. bobwop
    bobwop
    from Arley, AL
    we use one of those plastic "license plates" that the new car stores always put on the front bracked. Just hold it in one hand, bent to fit the curvature of the wheel. Spray with the other hand. If you do a lot, you will get it down to a smooth and easy routine...spray, spray, spray, move, spray, spray...
    works especially well when using BLACK
  16. Little Wing
    Little Wing
    from Northeast
  17. Stumpuller
    Stumpuller
    ive used grease on the valve stem before...
    anyone ever hear of rubbing the sidewall of old tires with used motor oil?
    its supposed to make old tires look nice again. my grandad told me they used to do this when they were trying to sell an old car or tractor.
  18. 327-365hp
    327-365hp
    from Mass
    I just painted my wheels black. But I didn't want my whitewalls black! So, I used 1/4" tape to get close to the wheel then more tape and masking paper for the rest. It worked great except it was a bitch getting that green tape of the white wall. Use the blue stuff that doesn't stick to anything!
  19. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    Lazy way from the professionals.. I took a Sunbeam Alpine I had worked on to sell to Earl Schieb's, this was early 70's. I told them please do not paint the wheels as I knew what they did. Sure as heck they sparayed the wheels too. Black tire paint was there lazy way to spray the wheels. Never been back to them since...I don't know if they still do that or not it was Tacky and I don't mean the sticky ness of the paint.
  20. carcrazyjohn
    carcrazyjohn
    from trevose pa
    When i was in my 20's Id spray rim and then brush paint my tires in flat black.
  21. vertible59
    vertible59
    He He...try that, then cruise down a Georgia dirt road. You'll Have red walls for sure!:D
  22. budrow
    budrow
    I've done it like this..take a large pice of card board, lay it on the rim and tap it pretty hard with your hammer all along the rim. This makes a good outline of the wheel ,cut it out, hold your new sheild agen the rim and rattel can your collor on the rim not on the tire, move the shild and do the next section. Took me longer tipe this than to make a paint shield.
  23. Deyomatic
    Deyomatic
    from CT
    WOW, there's a ton of responses. This is exactly what I'm looking for. There are a lot of great suggestions here so when my laziness (and the rain) wears off I'll get cracking. Black was the color that I was thinking, anyway. I masked the spare on my '60 a few months back and it took a bunch of tape for it to look nice, but that's white. I figured I'd need to find someone with a family discount at 3M if I want to mask all 4!
  24. THE_DUDE
    THE_DUDE
    If ya get any overspray use some bleeche white and a brass brush, it will come off
  25. plym49
    plym49
    from Earth
    Be careful using grease or petroleum jelly. The solvent in the paint from the over spray can dissolve it, making a fine old mess.
  26. unkledaddy
    unkledaddy
    I do something similar using two overlapping pieces of paper dry wall
    joint tape. Works great!
  27. plym49
    plym49
    from Earth
    The joint tape and the note cards: what great ideas! Solves a problem as it is a real PITA to mask around a wheel rim with tape.
  28. ShelbyStang
    ShelbyStang
    Ive always just used a deck of cards or notecards....
  29. Shifty Shifterton
    Shifty Shifterton
    The secret is to rip your tape into strips about 6 inches long. Otherwise it'll want to curl up on ya since it never sticks well to rubber. Once you lay one round, grab an old car mag, rip some pages out, and make your own masking paper by taping one edge. 7 or 8 pages and you're around the wheel. If you have actual masking paper, several individual pieces are key to getting it to lay flat.
    5 minutes a wheel. Tops. Do it right and you'll be able to paint 100% of the visible rim. Good luck
  30. Whatever you do, don't use WD40, the silicone in there will cause fisheyes in the paint.
