Panel clamps
Discussion in 'Questions & Suggestions' started by ironpile, Nov 23, 2005.
  1. ironpile
    ironpile
    Here is a panel clamp thats easy to make and works great. Made with 1" square tubing,3/16th threaded rod, wing nut ,washer, 1/8th " steel rod,strip of .040 sheet . Hole in sq tubing is 5/16th to allow ***embly, weld threaded rod to small piece of sheet metal,drill 1/8th hole 1/4" below weld.Cut slot in tube with cutoff wheel and ***emble. Use as many as you need to get good results [​IMG] IM000205#1 pic is how it looks in action [​IMG] IM000201 [​IMG] IM000202
  2. Paul
    Paul
    Editor
    is this a test thread?
    if you like it can be moved to the main forum.
