Technical Panhard Bar Questions
Discussion in 'Traditional Hot Rods' started by PhredH, Apr 10, 2017.
  1. PhredH
    PhredH
    For the Model A Ford ch***is and panhard bars:
    1) If one was only going to have only one bar, is a front or rear bar most beneficial?
    2) Other than ease of attachment:
    Does it matter if the bar is anchored to ch***is at the steering box side or the other side?
    Does it matter if a front bar and a rear bar are anchored to the same side of the ch***is, or should they be anchored on opposite sides?
    Thanks in advance.
  2. depends....what front steering? what rear suspension?
  3. Pete Eastwood
    Pete Eastwood
    from california
    That is not a question with a simple answer.
    Get a Pete & Jake's catalog & read the front section.
    gimpyshotrods likes this.
  4. Torana68
    Torana68
    from Australia
    how hard can it be? a panhard bar locates your axles under your ch***is, BUT exactly what suspension do you have front rear?
  5. Bugguts
    Bugguts
    There's a bunch of good threads on here about this subject. I took a lot of time and studied them all to get it right. My A has cross steer and definitely needed a front bar. That car would almost change lanes when hitting a bump in a left hand turn. Much better now.
  6. PhredH
    PhredH
    Stock front/rear springs with reversed eyes and leaves removed. Steering is stock. Warmed up 4 cyl engine.
  7. gimpyshotrods
    gimpyshotrods
    Then you need no panhard bars, front, or rear. If it needed them, Ford would have put them on there.
    You might want a front anti sway bar.
  8. Hombre
    Hombre
    What makes you think you need a Panhard bar? With your stock set-up it would just be a waste of time. Wouldn't hurt anything, but you have to ask why?
  9. Torana68
    Torana68
    from Australia
    yep what they said, and a +1 for having a look at sway bars....
  10. Mike VV
    Mike VV
    from SoCal
    Yes.
    No.
    Most defiantly, the same side.
    Questions not asked -
    Make them as long as possible.
    Notes -
    With a 4cyl engine, stock length shackles, as other's have said not worth the time/effort.
    Also, as has been mentioned, anti-sway bars will help cornering a lot.
    Mike
  11. pasadenahotrod
    pasadenahotrod
    from Texas
    IF the suspension is stock in dimensions to original Ford and springs are mounted under tension, i.e. shackles must be installed from spring to perch with a spring spreader, no Panhard bar is necessary.
    Fords from 28-41 were built this way then Ford changed to intentioned mounting and installed Panhard bars front and rear from 42-48.
