Technical Parallel leafs and cross steer, any issues?
Discussion in 'The Hokey Ass Message Board' started by Budget36, May 26, 2022.
  1. Budget36
    Budget36
    I’ve a dropped tube axle for a ‘46-8 Ford I’m going to put under a ‘32 Dodge PU with parallel leaf springs.
    it was side steer originally, but would like to run a cross steer box/column I have and keep it cross steer.
    Any issues?
    It’s been so long since I sold my ‘42 PU, I can’t recall if it was cross or side steer.
  2. Budget36
    Budget36
    Well Google is a good thing, I guess ‘42-7 Ford PUs are cross steer.
    Full steam ahead!
  3. 41rodderz
    41rodderz
    from Oregon
    Glad you got that clarification. :D
    Budget36 likes this.
  4. Budget36
    Budget36
    I’ll probably forget in the next hour or so;)
  5. Flat Roy
    Flat Roy
    The only thing I noticed when I put cross stearing in my 1950 F1 was that it wanted to flex the bottom of frame channels in and out an uncomfortable amount. This was easly fixed with a simple solid bar from one side of the frame to the other side in the appropriate place.
  6. Mimilan
    Mimilan
    Nope! Most 4 x 4 leaf spring front axles uses cross steer . Just set up the bump steer correctly
  7. 1971BB427
    1971BB427
    from Oregon
    Done tons of drop axle swaps using cross steer. Only thing you'll need is different steering arms to bolt to the backing plate on the p***enger side to convert to cross steer. The usual precautions of making sure everything is new or like new/tight, and set up properly. Clearance/slop issues on any beam or tube axle always lead to other problems once you begin driving it.
