Pardon my ignorance - SBC
Discussion in 'The Hokey Ass Message Board' started by Pickup Guy, Jul 7, 2008.
  1. Pickup Guy
    Pickup Guy
    from USA
    OK..
    I am confused.. I bought a motor was a 350 (supposed to be)
    It come out of a buick malibu,.. something> I was there when they took it out. Car had been wrecked and it had just come in to the junk yard. I was looking for a SBC for my street rod....
    SO anyway it was a 1976 model. I run across ANOTHER 350 motor and it was quite a bit newer. I wondered if maybe I might get it since maybe there would be much less wear. It's a 1983 or so model.
    Tore the 'new' motor apart today,.. and decided to check the numbers and see just what years the block showed...
    One block showed this as the numbers 14010203
    The first one I bought was 355909.
    got my info here... is this correct??
    http://www.nastyz28.com/sbchevy/sblock.php
    NOW both of themshow a C.I.D. of 305. Am I not reading something right... or are these 305 motors and not 350's
    Someone help me out. Now I'm confused.
    The 'new' motor even has the 'casting clock' that is mentioned on the link I listed...
    Someone who knows more than me... fill me in.
  2. Russco
    Russco
    from Central IL
    well the 14010203 is a 305 the other is either a 305 or a 262 but neither are 350's
    according to moretec
  3. Pickup Guy
    Pickup Guy
    from USA
    both the motors look identical.. so whatever they are.. I'd say they are the same..
  4. theHIGHLANDER
    theHIGHLANDER
    It'd help if ya had the 3 letter code off the pad in front of the p*** side cyl head. As an example, it should read like VO425MO with a smaller (sometimes) vin behind or just under it. The vin isn't always there. De-coding my example would tell us it was a 302 from a 67 Z28 built on april 25th at the Flint eng plant.
    V =Flint
    0425=April 25th
    MO =67 302
    The numbers you gave us indicate the block casting and can sometimes be used in multiple CIDs.
  5. theHIGHLANDER
    theHIGHLANDER
  6. HOT ROD DAVE
    HOT ROD DAVE
    granted its not a 350
    in my 1 ton wrecker its supposed to of had a 350, but the guys kept blowing it up so i put a 5.0 in and it has lasted almost 5yrs of abbuse, dont see a diff in power, i would build it in my opinion
  7. Larry T
    Larry T
    As far as size and general appearance, all small blocks from 262 to 400 are the same. Are there differances and ways of telling them apart? Yea, but not from 20 feet away.
    If you pulled the heads off, you might measure the bore. But the casting numbers and ID numbers accurate.
    Larry T
  8. Pickup Guy
    Pickup Guy
    from USA
    hhuumm I'll go check... be right back..
    we've been dis***embling the engine... One of the guys that sold us the motor was a long time friend of dads, and I fail to see why he;d lie about the size of the motor... also Dad is 80 years old and I think he pretty sure about a 350 when he sees one.
    I worked on 350's before I got disabled on a race team,.. and these look just like those... but part of my problem is confusion and memory loss.
    SO thats partly why I asked.
    I'll BRB
  9. Pickup Guy
    Pickup Guy
    from USA
    ok this is what it says...
    A25
    D N
    K31
    and it has thet clock face on it points to 5.... and outside dot is at top
    OH.. now this is on the side of the block...
    nothing on the front of the motor at all...
    anyplace else to look
  10. theHIGHLANDER
    theHIGHLANDER
    DNK is a 79 305 from a Camaro/Firebird. Build it. Be sure to get rid of the OEM cam. They were improperly heat treated and wore out fast taking most of the motor with it. With gas over $4.00 a gallon a 305 is a decent choice.
  11. Pickup Guy
    Pickup Guy
    from USA
    ok.. appreciate the info.. and you guys jumping in to help an idiot..
    couple questions if you don't mind...
    can you point me to where you found that. I always like to learn...
    Second.. Am I to understand that these same blocks were used to build both 305's and 350's..??
    Lastly.. what parts are interchangle on them...??
    thanks for educating me...
  12. Rich Rogers
    Rich Rogers
    same block, same stroke, just smaller bore. If it's a HO 305 it can run just as hard as a 350. Headers, cam and carb intake change will make one hell of a differance. I've done it and damn near hit a fresh 4 bolt main 350 in the *** racing it actually I had to back out of it alittle so I woudln't hit it
  13. Pickup Guy
    Pickup Guy
    from USA
    so the bore.. do you just measure.. I ***ume you have to 'mic' it..??
    All I have here at the present time is a tape measure...
    closest I can tell with what I have is about 3.75
  14. Pickup Guy
    Pickup Guy
    from USA
    seems everything keeps pointing back to a 305...
    I found this
    best I could measure with a tape measure was 3.75 and stroke was 3.5... pretty close to what the measurements show above... hhuummm
  15. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Unless you want to make a lot of HP the 305 is a good motor. Ive had one in my 38 chevy coupe since 2001 and its been a lot of miles at 20 MPG +. Didnt plan on using a 305 but had a low mileage one that came out of my sons wrecked S10 that was ready to go at the time I was ready for an engine for the coupe. Havent regretted it.
  16. Pickup Guy
    Pickup Guy
    from USA
    cool.. thanks everyone for the replies... keep them coming.
    I am about to build this motor.. need all the info I can get.
    Just fo9und out today all this where I am...
  17. Pickup Guy
    Pickup Guy
    from USA
    OK.. latest news... found out I have the 'hot' 305 set up...
    601 heads, so I now question.. is the CAM still a "bad" one like someone mentioned above and chould be automatically replaced... or is it a 'better' one like the heads, etc that come with this block..??
  18. Pickup Guy
    Pickup Guy
    from USA
    OH.. I got a Holly carb for it... just happend to pick it up cheap... too cheap to p*** up.
    I'm sure it'll need to be rebuilt.. but even a rebuild kit, and someone rebuilding it is WAY cheaper than a new one.
    not sure which one it is... been trying to find some numbers in it,.. and a place so I can figure all that out. It has four holes all the same size. I'm thinking this is a good thing..?
  19. LOST ANGEL
    LOST ANGEL
    DOOD, jam the 305 in there. Like they said, put a decent cam in there and your good to go. Mine is a 1978, with who knows how many miles, and gets a bazillion miles to the gallon, more or less. Goes zero to speeding ticket in no time, and is a blast to driv. Have fun with it!!-MIKE
