1952-59 Ford "Parental Guidance" project progress..
Discussion in 'Off Topic Hot Rods & Customs' started by bigbren, Apr 13, 2012.
  1. bigbren
    bigbren
    I got my block torn down!!!! After I get my parts back from the machinist I was wondering if I need to paint the block and other parts right away?
    Also.. I was thinking of using spray paint on the block and other parts? Will that be fine or wll it flake off right away? Let me know your opinions please. A friend of mine said I would be stupid to spray can it.
    Thanks in advance.
  2. 54HotRod
    54HotRod
    There is a high heat spray paint that you can use on the engine block that will be fine and keep a nice color and shine. You can buy the paint at Lowe's.
  3. bigbren
    bigbren
    Thanks. That's kind of what I thought. I'm thinking black block with chrome heads.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    Dupli-Color has a ceramic engine enamel in spray that is supposed to be glossier and more durable.
  5. Ole don
    Ole don
    I have had very good luck with the new Duplicolor ceramic rattle cans. Clean the part with acetone and blow it dry, put on a very light coat of epoxy primer, then about three or more light coats of color.
  6. bigbren
    bigbren
    Thanks guys. I am really excited to start putting things back together!
